TBI smokin out
Old Nov 21, 2018 | 03:59 PM
67ssimp's Avatar
TBI smokin out
I have a 91 camaro rs with a 305 for a weekend car. Haven't cranked it in a couple months. Started it today and it ran and drove ok. Brought it home and when I opened the hood to investigate a strange smell I saw smoke coming out of the air cleaner from the TBI. The car has about 190,000 miles on it. I have never encountered a problem like this, hope somebody can shed some light on the situation.
Old Nov 21, 2018 | 05:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TBI smokin out
Are the wires to the injectors pinched ?
Old Nov 21, 2018 | 06:33 PM
67ssimp's Avatar
Re: TBI smokin out
No, I checked the wiring and connectors. It all seems to be ok.
Old Nov 22, 2018 | 09:46 AM
PaulyC's Avatar
Re: TBI smokin out
Is it happening every time you drive it or only when you shut off or something else? Maybe try and remove the air cleaner cover to see if you can tell where it originates.
Old Nov 22, 2018 | 07:30 PM
67ssimp's Avatar
Re: TBI smokin out
This is the first time it has happened. Busy weekend ahead but when I have time to further investigate I'll post again. It's a issue that I've never heard about and can't seem to find any info online.
Old Nov 23, 2018 | 12:54 PM
Schurkey's Avatar
Re: TBI smokin out
Two likely causes:
1. Electrical smoke from shorted wire or overheated electrical components
2. Excessive blow-by or a defective PCV system, blow-by is coming out the crankcase and into the air cleaner. It's supposed to do that under heavy throttle. Shouldn't do it at part-throttle or idle.
Old Nov 28, 2018 | 05:37 PM
67ssimp's Avatar
Re: TBI smokin out
After checking the vacuum on the PCV system and other vacuum lines I decided to pull the air cleaner assembly. I found remnants of a palmetto bug that must have climbed into the air cleaner while the car was being stored and I believe that it was the likely culprit. Had the camaro running for a good while today and didn't see any smoke coming from the TBI. Thanks for your replies.
Old Nov 28, 2018 | 05:55 PM
PaulyC's Avatar
Re: TBI smokin out
I had no idea what a palmetto bug was, then I googled it. I would move away.
Old Nov 28, 2018 | 06:05 PM
67ssimp's Avatar
Re: TBI smokin out
I live in North Florida and they are everywhere. They really suck. The smell from the one that got barbecued in my air cleaner was quite atrocious.
Old Nov 29, 2018 | 10:05 PM
Sweatlock's Avatar
Re: TBI smokin out
'Palmetto bug' is just a nice way of saying 'freakishly large cockroach'. And yes, they're everywhere down here in FL.
87transam5.7tpi
Mar 14, 2002 12:45 PM
Alan84TA
Carburetors
Nov 29, 2001 12:54 PM
SillyWabbit
Car Audio
Aug 15, 2001 02:24 AM
Dan91Z
Jul 7, 2001 11:25 AM
Twin Turbo 358
Jan 25, 2001 08:24 PM
