White smoke from TBI?
Old Mar 5, 2019 | 08:05 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Hey TGO,
I tried starting my parts car w/ potential and she ran REALLY REALLY rough. As I backed it in the driveway it cutoff like someone pulled the plug. I jump started it again, it ran like crap again for about 45 sec or so and I happened to notice some white smoke came up from the TBI, almost like an thin mushroom cloud as it died. I know the car has sat un-started for some time but when checking the Oil it didn't look like sludge or milky. When checking coolant it was as green as any other 50/50 coolant, When the weather breaks i'm going to pull plugs, check wires, cap & rotor button, etc but in the mean time I was looking for any of your experiences starting cars that have sat 6mo +
Now that I typed this up, it's almost like the plugs aren't burning off the fuel being supplied...
Any direction or input would be appreciated, Thanks.
Old Mar 6, 2019 | 01:45 PM
Engine: 305 / 350
Re: White smoke from TBI?
Although it's still freezing out here in ohio, I did do another quick once over and realized the following was disconnected...
- Vacuum Line to Coolant Bypass Valve
- IAT Sensor
Reconnected IAT Sensor & Vac Line & Changed the Blown 20A ECM/FP Fuse. Battery is indoors on charge, will report back when it's above 40 degrees.
Old Mar 6, 2019 | 07:02 PM
Engine: 305 / 350
Update: Matter Resolved
Couldn't wait until a 40+ degree day so a bit ago I grabbed the battery off the charger and hooked it up. Tried to start, 1st two times were rough but it started, ran a bit smoother and NO MORE White smoke from the TBI. I now conclude the disconnected Vac line and IAT being disconnected & overlooked on my part was causing a quite critical rich condition, etc, etc.
Old Mar 11, 2019 | 11:05 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Could be bad gas too. It really doesn't have a long shelf-life.
rwriley563
Aug 8, 2012 09:29 PM
87IROCZCamro
Apr 10, 2010 01:23 AM
hitmann91
Dec 21, 2008 09:21 AM
jeeps2creep
Jun 13, 2006 12:54 PM
SERPENT99
Feb 11, 2005 09:52 PM
