IAC plug is missing plastic
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My IAC plug is missing plastic where it connects to the IAC. It doesn't doesn't appear to be a problem as far as getting a connection, bit once in a while I get a surge at idle. It comes out of no where. It's a 92 RS, with TBI any input would be helpful
Re: IAC plug is missing plastic
My question is does the plastic around the prongs have a function as far as getting a connection?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The plastic connector helps align the inner terminal. Even if it’s busted as long as the latch tab on the connector is there there should be a good connection. It’s easy to unpin and install a new weatherpak connector.
https://www.ebay.com/itm/Delphi-Weat...kAAOSwUu5b~IAl
The rubber seal is good, but the latch tab is broken off. I just ordered a new pigtail on ebay.
Engine: Lb9
Transmission: M20
The terminals release easily. No need to hack the harness unless you have to.
https://www.ebay.com/itm/Delphi-Pack...4AAOSwgotcR13F
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Engine: Lb9
Transmission: M20
just watch the letters on the back of the connector so you get the wires orientation right. Last edited by Tuned Performance; Mar 26, 2019 at 11:20 AM.
DanielRicany
Feb 19, 2018 07:33 AM
Malicious3rdgen
Oct 28, 2013 01:43 AM
