5.7 tbi clean up
Old Apr 24, 2019 | 01:42 PM
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
5.7 tbi clean up
Hey guys I have a 5.7 tbi and would like to know what all I can remove and it still work good. EGR valve ? Charcoal canister ?
I know I have to keep a vacuum hose for the map sensor but is that it?
And if I remove all that stuff will I need a new chip?
Old Apr 24, 2019 | 02:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 5.7 tbi clean up
Keep the ccp. If you remove the egr you will get a code 32. Unless you have a prom burned.
Old Apr 24, 2019 | 06:36 PM
Drew's Avatar
If you don't know, you shouldn't be messing with it.
Old Apr 25, 2019 | 01:58 AM
Schurkey's Avatar
THANK YOU! Thankyouthankyouthankyou.
Old Apr 25, 2019 | 07:28 AM
makaveli09's Avatar
Engine: 350sbc
I am not a tbi guy. Kinda new to this hole computer thing.
Old Apr 25, 2019 | 08:30 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
What chip are you running in it now the stock 305 chip? If so you are leaving power on the table there already.
Old Apr 25, 2019 | 11:31 AM
makaveli09's Avatar
Engine: 350sbc
I was told the motor and ecu came from a truck.
Old Aug 11, 2019 | 06:25 PM
Larry82's Avatar
Stock prom with egr blocked off at intake and all smog equipment removed. No codes whatsoever Been like this for about a decade
Old Aug 12, 2019 | 05:42 PM
Schurkey's Avatar
Does the computer work properly? Have you checked the memory and the data stream with a scan tool? I'd have expected that to set and store codes.
I've had people tell me that their modified vehicle doesn't show codes...and then found out that the MIL is burnt-out; the codes are stored but can't illuminate the dash light.
Zerocyde
Nov 3, 2010 11:31 PM
TBI89Formula
Mar 7, 2005 09:55 PM
iroczrockz
Jan 11, 2003 03:01 PM
InDa12's
Jan 30, 2002 01:06 PM
