Sending unit
Old Aug 23, 2019 | 07:56 AM
Snowks's Avatar
Sending unit
Having trouble finding a replacement sending unit for a 1982 tbi. Still have the original gas tank. Any suggestions?
Old Aug 23, 2019 | 08:56 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Sending unit
? wasn't 1982 carbureted not TBI? Pretty sure RockAuto has one the last time I looked it up for someone.
Old Aug 23, 2019 | 09:44 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Sending unit
Carbonated???...
Old Aug 23, 2019 | 09:53 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Sending unit
LOL sorry phone typing auto completion ... Carbureted not carbonated --- edited it
Old Aug 23, 2019 | 10:03 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Sending unit
Odd looks like if you look up 86 you get https://www.rockauto.com/en/moreinfo...35593&jsn=1395 but if you look up 82 you don't get a sending unit listed. However the same tank part number is listed between 86 and 82... so that is interesting. I would say the sending unit for the 86 carburetor car would work but the wiring and fuel lines may be different so you may have to make it work.
Looks like the GM part number for 82 was one of the following 25003093, 25003095, 25003096
http://www.gmpartswiki.com/getpage?pageid=36387
Old Aug 23, 2019 | 04:18 PM
Schurkey's Avatar
Re: Sending unit
WHAT ENGINE?
WHAT CAR?
Could you provide any less information?
Old Aug 23, 2019 | 10:43 PM
Snowks's Avatar
Re: Sending unit
305 crossfire injection. Only thing I found was Hawks Motorsports has someone that will refurbish your old sending unit. Not cheap, though.
Old Aug 25, 2019 | 09:20 PM
Schurkey's Avatar
Re: Sending unit
WHY do you need a new sending unit? What isn't the original sending unit doing that it should?
Old Aug 31, 2019 | 02:49 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Re: Sending unit
Probably same thing my fuel sender isn't doing - indicating the correct fuel level. Mine's full when full and is between 1/4 and 1/2 when empty.
If you do a Google search, several companies come up that can refurbish fuel sending units. I bet Hawks uses one of them.
Old Aug 31, 2019 | 09:28 PM
Schurkey's Avatar
Re: Sending unit
I'd like to hear it from him, to be sure.
MIGHT be the sending unit. It IS possible.
More likely, high resistance in the wiring between the gauge and the sending unit, or between the sending unit and ground. SOME sending units are known to have the resistor element get contaminated with sulfur compounds; some Techron in the gas tank will take care of that.
Snowks
Aug 23, 2019 04:19 PM
DARKmj16
May 10, 2013 09:29 PM
Jr. Mechanic
Carburetors
Jul 1, 2009 11:17 PM
