Need help with TBI VATS delete
Hi, I'm new to this forum as a member, but have lurked for years. A member of the FB page LSX swapped Third Gens recommended some users here might be able to help.
I have a low mile 1991 RS 305 TBI 5-speed car. Recently I've had intermittent VATS faults. Randomly it will not crank and not deliver fuel. I bypassed the starter enable relay and I have spark and fuel pressure. I do not have injector pulse. The resistor key and lock cylinder are almost new. I believe the VATS module is showing its age, and just want to permanently disable VATS.
In summary, I'm looking for someone who can send me a stock chip with VATS and EGR turned off, or that I can send my chip for the same setup. I am planning on LS/T56 swap in the spring, I just would like to be able to drive the car in the meantime and I would like to avoid investing in the kit to burn my own chips since I'll likely never need it again. I'm willing to pay someone who already has the kit to burn chips to help me out.
Thanks!
Thanks!
Engine: 5.7 L98
Re: Need help with TBI VATS delete
TunedPerformance is the guy you want.
Engine: 5.7 L98
He has his own site where you can reach him directly and you will have to fill out a brief questionnaire of what you need/engine spec,
www.tunedperformance.org
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Pm sent , thanks for the recommendation reddragon88gta
