Advance on LT4 cam
Old Jan 16, 2002 | 10:26 AM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Advance on LT4 cam
I am going to be installing an LT4 cam in a while. I got a new timing chain and gear set. I was wondering if you guys install the cam with some timing advance or just line the dots straight up? Just want some opinions. Thanks
Old Jan 16, 2002 | 11:13 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Advancing a camshaft promotes low-end power...
Retarding a camshaft promotes high-end power...
If you've got some high flowing intake and exhaust modifications it might do to install it a bit retarded. If you've got mostly stock intake/exhaust it might do to install it straight up or slightly advanced.
I would install it straight up.
Old Jan 16, 2002 | 11:38 AM
BahamutRS's Avatar
You're going to gain enough with it installed straight up, so I wouldn't worry about anything.
Old Jan 16, 2002 | 01:22 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Thanks. I do have intake and exhaust mods. I was planning on just doing it straight up anyway but just wanted some more input.
Old Jan 16, 2002 | 06:02 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I used the LT-4 cam in my 305 and it brings good power so I got one for the 350 we built and it is strong!!!! However you never said what heads you have (remember the LT-4 has high lift) make sure you have valve stem clearance. I installed my cam straight up, thats the only way I would do it.
Brian
Old Jan 16, 2002 | 09:22 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
I still have the stock heads right now. But I am looking forword to seeing what kind of gains I will get from the cam. THanks for the advise.
masonta
Aug 31, 2015 10:14 PM
lt1z350
Aug 28, 2015 05:57 AM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
