Wanted: Roller Lifter Setup.
Old Jan 16, 2002 | 11:05 PM
Nate Hanson's Avatar
Hey guy's-
I'm looking for a slightly used Roller rocker setup to convert my LO5 hydraulic 350 to the roller lifter setup. I have the provisions and everything on my block. I'm switching to a LT1 cam soon.
nate
Old Jan 17, 2002 | 06:26 PM
fast_broker's Avatar
Only $180 from a dealer NEW for lifters, lifter locators, locator spider holdown, spider bolts/washers.
you'll also need a special t-chain KIT from GMPP that includes the t-chain and the plate and screws taht hold the cam in the block. flat-tappet t-chain won't work on an OEM roller cam like the LT1.
Also, need 7.200" or so long pushrods, not 7.8" flat-tappet pushrods. Also, need new valve springs, in most cases, to take the ramp speed and stop valve float.
Old Jan 17, 2002 | 08:21 PM
ChevalierSS's Avatar
do a search on ebay for "lt1 cam". There was an auction on there earlier today for the cam and all of the roller goodies.
Old Jan 18, 2002 | 04:10 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I have a set out of my 89 tpi bird. Would they work. Let me know if they would and I give them to ya for $50, shipping included.
Old Jan 21, 2002 | 07:49 PM
Dominic Sorresso's Avatar
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Nate,
I am converting over to a split set of 1.6/1.5 Crower Stainless Steel Roller Rockers. Currently they are all 1.5. So I could sell you 8 slightly used rockers (3k miles) with you buying another 8 from Crower. They will sell split sets. Let me know if you are interested
Old Jan 22, 2002 | 12:07 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Does anyone have that part number for the T chain with plate and screws.
Thanks,
Old Jan 22, 2002 | 12:14 PM
GMPP P/N 12371043 = timing chain/gears and roller cam retaining plate kit (1st and 2nd design plates!)
GMPP P/N 12371042 = 2nd design (higher ball preload) roller lifters (16) with (8) lifter aligners and (1) spider hold-down and (3) spider attaching bolts/washers.
GMPP P/N 10456413 = bronze HEI (large-cap, non-computer controlled internal-coil HEI) gear for use with steel roller camshaft.
Anyone have the P/N for the bronze/roller gear for the external-coil TBI small-shaft distributors???? For steel roller cam use?
Old Jan 22, 2002 | 12:19 PM
Thank you.
Old Jan 22, 2002 | 12:58 PM
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Fastbroker,
I don't think you want to use a bronze gear on the distributor. Make certain that whatever cam you get comes with a ductile iron distributor gear on it. CompCams sells their cams this way.
Old Jan 22, 2002 | 06:50 PM
If you use a non-bronze gear with a GM steel camshaft, you are in for trouble. All we've been talking about is GM cams, lately. You've all been warned.
KO1
16
Oct 15, 2015 05:00 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
