Throttle Body Issue
Old Feb 10, 2022 | 08:13 PM
IronMtnMoose's Avatar
Car: 1990 RS Camaro
Axle/Gears: 3.08
Throttle Body Issue
So I was finishing up my top end rebuild and noticed fuel gushing from the passenger side inlet on my throttle body. Turns out the threads in the throttle body are completely trashed. My car is a 90 and I know they changed in 89 but are there any differences on the truck TBI throttle bodies? Has anyone successfully fixed a mess up like mine or have one that will work that won't make me file for bankruptcy? Help a hillbilly out.
Old Feb 10, 2022 | 09:33 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Throttle Body Issue
You may want to wait for a more definitive answer, but this seller specializes in TBI systems and parts. If his ad is to be believed, they are the same. And this pair is available for $22.
https://www.ebay.com/itm/19220736669...4AAOSwhvFZNBPr
Old Feb 11, 2022 | 05:46 AM
Car: 1990 RS Camaro
Axle/Gears: 3.08
My fittings are fine. Sadly I stripped the throttle body itself.
Old Feb 11, 2022 | 08:21 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Get a used unit from any GM TBI V8 (sans 454, they have larger bores) and swap over your stuff onto it. Any junk yard should have one.
Old Feb 11, 2022 | 08:44 AM
Car: 1990 RS Camaro
Axle/Gears: 3.08
I've got my brother looking at his local U-Pull. Hopefully we can find something cheapish.
Old Feb 11, 2022 | 03:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Just need the injector pod, that is where the fuel lines thread in. Can get one from any number of TBI units, install your injectors and bolt it down. Good time to clean it all up and use a rebuild kit.
RBob.
Old Feb 11, 2022 | 03:23 PM
Car: 1990 RS Camaro
Axle/Gears: 3.08
RBob.
Awesome. Sounds like the way to go.
Old Feb 11, 2022 | 07:28 PM
Schurkey's Avatar
There's numerous detail changes in the TBI units over the years, and perhaps among applications--car vs. truck, for example.
Some changes are fairly meaningless--there may be differences, but either version works just fine.
Some trouble can be had if the wrong gasket is used with a given throttle body, for instance.
Point is, be careful what you swap. Pay attention to the old gasket, or the old fuel pressure regulator, or the number/position of vacuum nipples.
Old Feb 11, 2022 | 07:34 PM
Car: 1990 RS Camaro
Axle/Gears: 3.08
A friend of mine had a junked 2.8 so I'm going to use the pod from it. From what I can see the pods look identical. Swapping out just the pod and keeping all of my 305 throttle body should work just fine shouldn't it?
Old Feb 12, 2022 | 01:55 AM
Schurkey's Avatar
As said in a previous post...put the 305 injectors into the replacement pod. While the pod is apart for the injectors, verify that the gasket surface is genuinely flat.
I used 220-grit sand paper on a piece of window-glass (for flatness) to take the warp out of mine.
I would verify fuel pressure when you get the throttle body installed again.
Old Feb 12, 2022 | 04:41 AM
Car: 1990 RS Camaro
Axle/Gears: 3.08
Awesome. Thanks for all the info folks. Hopefully I'll have her livin' again soon.
del91_305
Aug 29, 2019 11:54 AM
studdmstr
Nov 25, 2002 11:57 PM
