Can anyone make sense of these WinAldl logs for me
Old Apr 10, 2022 | 08:28 PM
Stevo427's Avatar
Car is a 1988 Sport Coupe 305tbi/700r4. The car sat for 12 years (It was my fathers).......So far I've replaced the fuel pump, plugs, cap/rotor, plug wires, fuel lines, vacuum lines, injectors, gone through most the grounds, and probably other things I haven't thought of. The car idles high and runs insanely rich (burn your lungs rich). I cant find my timing light currently so I have not timed the car although I didn't move the dist. at all. I also never changed the regulator but it looked fine. I'm new to this type of ECM I'm used to working on carb cars and new cars. Any help would be appreciated.
File Type: txt
File Type: txt
File Type: txt
File Type: txt
File Type: txt
Old Apr 11, 2022 | 05:17 PM
Stevo427's Avatar
Re: Can anyone make sense of these WinAldl logs for me
Well today I went out and replaced the regulator and spring. Started the car and it started idling high but I noticed the passenger injector dumping fuel. Took it back apart and the o-ring was busted. Put it back together and for the first time I’ve ever owned the car it went through the whole idle down process and ran correctly. Smokes at idle but I think that’s just the PCV being disconnected.
Old Apr 11, 2022 | 05:42 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Congratulations!!!
Camaroman575
Feb 27, 2009 09:54 AM
IROCmenace
Nov 25, 2007 11:54 AM
badinfluenceRS
Jul 24, 2007 12:30 AM
92RS87Z_Driver
May 25, 2002 12:17 AM
92RS87Z_Driver
May 23, 2002 08:32 PM
