VSS Buffer wiring
Old Feb 11, 2025 | 01:44 AM
Brian Poarch's Avatar
VSS Buffer wiring
Hey guys I need some help. I have 92 camaro rs. It came with a v6. I swapped in a 5.0l TBI engine, harness and ECM from a long gone donor car. My car doesn't have a buffer box. I have a dakota digital sgi-5e. I struggle with wiring and I'm not sure how to wire it in so my speedometer works correctly. And do I need to move any wires around in the c207 connector? Can anyone help me with this?
Old Feb 11, 2025 | 08:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VSS Buffer wiring
The sgi-5 is alittle tricky to calibrate. The sgi-100nt is much easier I’ve heard.
c207 has a brown wire to speedometer. With any sgi you need a Vss signal in and out. Accessory power and ground.
Old Feb 11, 2025 | 09:46 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
SGI-100BT, might be the same wiring
https://www.thirdgen.org/forums/elec...sgi-100bt.html
Old Feb 11, 2025 | 10:15 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Looks similar to the 100BT I put in my friends 86 trans am
https://www.thirdgen.org/forums/tran...ml#post6534615
SLPhoenix92
Apr 15, 2024 12:17 PM
tlgrooms
Jan 13, 2022 08:02 PM
Kubrickfan
Jan 13, 2022 07:53 PM
nova1396
Sep 18, 2011 10:46 AM
BDK
Nov 1, 2005 03:23 PM
