heads
Old Jan 31, 2002 | 09:28 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
heads
if i get my stock 305 tbi head port and polished and maybe get a 1.94 intake valve put in would that make a huge diff or would it be cheaper to get the s/r torquer 305 heads and bolt them on. also with the l31 vortech heads i woudl have to get them milled but how much would that cost cause i hear they flow better then and world or dart head
Old Jan 31, 2002 | 10:52 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Don't waste your time/money with the stock heads, they stink. The L31 heads are really good heads, but as you said you'll have to get them milled and you'll have to get a Vortec specific intake manifold. The 305 torquers aren't a bad head, but they don't flow as well as the Vortecs. You won't have to get 'em milled nor will you need a special intake. The heads themselves cost more, but in the end will probably end up being a bit less expensive than going with the Vortecs.
I'd go Vortec if I were you...just my opinion.
Old Feb 2, 2002 | 07:30 AM
DM91RS's Avatar
Car: 91 RS
Regardless of what's been said the Vortec's don't have to be milled and they run very strong.
Old Feb 2, 2002 | 12:43 PM
Car: 89 Formula
Engine: Carbed 5.7
they said u need to have them milled or u will lose compression. and my compression is already 9.3 so what do u think it would drop it down to if i put the vortec heads on and don't get them milled? also i figure no matter how far it drops it u still gotta be better off with the vortecs then the ****ty tbi heads
Old Feb 2, 2002 | 06:14 PM
DM91RS's Avatar
Car: 91 RS
The compression loss is overrated. All I know that it's a different engine (much stronger running) after installing them.
Old Feb 2, 2002 | 07:10 PM
Buck268's Avatar
OK, so, these S/R heads are excellebnt compared to stockers, but not quite as good as L31's. But they dont need to be milled to keep compression. They are more expensive off the shelf. Uh, whats their PN? Also, about what prices would I be looking at for new, COMPLETE assebmlies of the vortecs (L31), and the S/R's? THanks
Old Feb 3, 2002 | 12:13 AM
Keith5's Avatar
Car: C1500
For new L31's look at www.paceparts.com www.sdpc2000.com and www.jegs.com .
They used to be $220 a head I think. They went up recently though, think they are somewhere around $240 now.
Old Feb 3, 2002 | 12:17 AM
Buck268's Avatar
$228 fully assembled + S&H + other expenses. Dont sound to bad to me. Now, to find money....lol
Old Feb 3, 2002 | 02:07 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
8060KIT SDPC SDPC Vortec head kit 699.95
L31 vortec heads - assembled
Edelbrock performer manifold (4bbl)
1.5 self aligining roller rockers
All mounting hardware
Head gaskets
from Scroggins Dickey
Buy the holley 4bbl - tbi adaptor and you're set to go.
Old Feb 3, 2002 | 07:57 AM
Buck268's Avatar
Well, if I ever scape together maybe I'll do it...I mean, I gotta pull the top end apart anyway to drop my LT1 cam in...
Who sells the 4bbl TBI adapter? I havent seem one @ summit or jegs, I guess I could have just not seen it though...
Edit - was looking through scoogn dicky, and found a 'vortec heads kit'
has L31 heads, performer intake and other stuffs...
http://www.sdpc2000.com/cart.asp?act...d=277&pid=1120
lemme know what ya'all think!
Old Feb 3, 2002 | 09:24 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
take a look at chucks post, the one right above yours
Old Feb 3, 2002 | 07:28 PM
Buck268's Avatar
LOL. Oops
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
