Car sounds like it has a turbo
Old Feb 3, 2002 | 10:33 PM
89 4Mula 350 Tbi's Avatar
After doing a brake stand for about 2 seconds my car started making a whistling sound when you would step on it. I have that edelbrock triangle foam filter i just thing the filter has something stuck in it. What do you guys think could be causing this its been an on and off thing for the past two days.
Old Feb 3, 2002 | 10:38 PM
Tas's Avatar
Tas
that's one of the worst air cleaners you can get. It's known for coming apart and getting sucked into the enigne. Besides that, the fringe benfit of a TBI is that it makes great sounds
Old Feb 3, 2002 | 10:45 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
If the rear bearing on the alternator is going bad it will sometimes whistle (tensioner pulley too) and gets louder with acceleration. You might wanna check those out and they are easily enough solved. Now if we could just talk AC Delco into putting larger rear bearings in their alternators!!!
Old Feb 3, 2002 | 10:51 PM
mattRS's Avatar
could be a vacuum leak. also, a buddy of mine had a fault water pump and it sounded the same.
Old Feb 4, 2002 | 12:40 AM
HrdRockA4305's Avatar
I thought about getting one of those triangle filters until I checked one out in person and realized how much they really suck. I do like the idea of being able to pull air straight down though instead of making the right turn before going down into the bores. Carbs like to melt those things when they backfire too (seen it)
Mine whistles when I'm above about 2000 RPMs, or at least it used to (haven't had the windows down to hear it much lately) and its just from the aircleaner.
Old Feb 4, 2002 | 12:44 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
mines doing the same thing started 2 days ago
Old Feb 4, 2002 | 10:52 AM
TBI305Camaro's Avatar
when i start my car in the cold or while at high rpms it whistles LOUD sounds like i have a twin turbo or something. it is easily heard over the exhaust and since i have the open element and removed my hood seal its loud
Old Feb 4, 2002 | 11:38 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Yea, like a few people have said about the alternator. When the bearings start to go it'll whine pretty loudly. Pop your hood and listen to your front accessories... see what happens.
Terrell351
Jun 13, 2021 01:13 PM
midias
Aug 22, 2015 01:42 AM
MY87LT
Aug 17, 2015 08:43 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
