Eldelbrock pro flo 14x3 cleaner install questions...
Old Feb 10, 2002 | 10:52 AM
RS'er's Avatar
I instaled my cleaner last night,but I'm just wondering what I should do with the little sensor that I had to disconnect. Should I drill a hole in ym air cleaner and mount the sendor in it and hook it up so I dont get anymore check engine lights?
Old Feb 10, 2002 | 12:53 PM
BlackBird92's Avatar
Car: 1992 Firebird
Engine: 305 LO3 TBI
<Should I drill a hole in ym air cleaner and mount the sendor in it and hook it up so I dont get
anymore check engine lights?>
Yes, exactly.
This is your intake air temperature sensor and it should be located within the aircleaner to let the ecm read the temperature of the air entering the engine.
Old Feb 10, 2002 | 01:28 PM
mattRS's Avatar
i have the IAT sensor just laying where it isn't touching any parts, just air, and its fine. i unplugged the actual sensor and got a light, so i plugged it back in and no prob at all. as long as it has air around it, there shouldnt be a problem. thats my experience at least
Old Feb 10, 2002 | 02:22 PM
Car: 1992 Firebird
Engine: 305 LO3 TBI
Yes, you can do it like this, too, to clear the problem with the "check engine" light coming up.
But keep in mind, that the engine's states of operation are controlled by the ecm. The ecm needs input from the various sensors located on the engine.
Depending on the data it gets it determines spark advance, mixture, etc.
Colder air means richer mixture, warmer air means leaner mixture, espacially at part throttle operations.
By not providing the correct temperature of the air when it is entering your engine, you could probably end up with a wrong mixture (too lean or too rich, depending on operating conditions)to a specific condition.
So I decided to drill a hole in my open element air cleaner base and to install the IAT sensor in it.
Just my thoughts.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
92purpz28
Aug 11, 2015 02:30 PM
