Weight reduction
Old Feb 12, 2002 | 07:37 AM
FRMULA's Avatar
Weight reduction
What happened to the "Drag Racing" Forum?
Anyway I have TBI car that I race and I have decided to remove the A/C. (Never used it since I bought the car in '93) I noticed in the Tech section that the weight is listed at 46# is this just the Compressor or the whole system? (evaporator, condenser, etc.)
I know March makes an idler pulley to maintain proper belt configuration.
I have also seen on eBay, ONCE, the firewall housing for 3rd gens with A/C delete, anyone know a source for these?
Thanks for any help
Old Feb 12, 2002 | 08:18 AM
TBIWorks's Avatar
It is the whole system, there is no way a compressor weighs in at 46#, more like 8#.
Old Feb 12, 2002 | 08:51 AM
FRMULA's Avatar
I've had the compressor out once before, If that thing only weighs 8# then I need to start working out again... Felt more like 15-20# but when I remove it for good I WILL weigh it and let you know
Old Feb 12, 2002 | 08:56 AM
Keith5's Avatar
Car: C1500
Re: Weight reduction
Thanks for any help
GM makes that idle puller too. They should still make it, I think it's like $40 or $50 new. That A/C delete box is kinda hard to get. I've seen them go on ebay for $50. You might find them in a local junkyard that still has 80's junkers. Early base model cars would be the easiet ones to find that should have it.
Old Feb 12, 2002 | 09:30 AM
TBIWorks's Avatar
Okay, it probably does weigh more, I've had mine out too, can't remember how heavy, but not over 20.
Old Feb 12, 2002 | 12:12 PM
vjo90RS8's Avatar
Car: 2002 Z28
members.aol.com/iroczdave/pubpage.html
I just got my AC delete heater box with blower motor and fan blade for $68 (includes shipping) from IROCZDAVE, if you go to his website you will see that he has another one for $60 plus shipping. Most of my AC is already out (compressor, condensor, accumulator, and all the external hoses) and the rest (AC box, blower motor, evaporator, and wiring) is going out this weekend. I also have an AC delete pulley which i got from gmpartsdirect.com for about $50 after shipping. Ill be happy to post pics when i am finished.
Old Feb 12, 2002 | 12:46 PM
FRMULA's Avatar
Thanks for lead...
btw how much weight did that take out of the car so far?
Old Feb 12, 2002 | 12:56 PM
vjo90RS8's Avatar
Car: 2002 Z28
ill weigh it all when i get home this weekend, but probably a good 20+ pounds so far. probably when im all done it will be around 30-35 lb. But ill get some exact numbers this weekend
Old Feb 12, 2002 | 01:05 PM
FRMULA's Avatar
What is the GM part number for the idler pulley?
using that website is like trying to learn english with a dictionary.
Old Feb 12, 2002 | 05:14 PM
vjo90RS8's Avatar
Car: 2002 Z28
AC delte pulley: 10055890
Old Feb 13, 2002 | 07:13 AM
FRMULA's Avatar
wtf?
I entered the part # you gacve me this is what came up...
10055890
Water Pump Pulley
PULLEY AS
$61.24
$45.93
$36.74
is this right?
Old Feb 13, 2002 | 10:52 AM
Keith5's Avatar
Car: C1500
Re: wtf?
10055890
Water Pump Pulley
PULLEY AS
$61.24
$45.93
$36.74
is this right?
I did a search in the archives. That is the number that always comes up. Even though it's coming up as a water pump pulley, I'm sure it's the AC delete pulley. I've put stuff in on there and gotten a different name back before too.
Old Feb 13, 2002 | 11:34 AM
FRMULA's Avatar
Does the idler pulley use the existing mounting points on the aluminum bracket that the compressor is attached to? I just reuse my old bolts to mount it right?
Old Feb 13, 2002 | 12:25 PM
Keith5's Avatar
Car: C1500
I'm not sure if you can use the same bolts or not, I'd would think so though. Here's a picture of the one on my friends car.
http://www.geocities.com/david_somer...s/dcp_0056.jpg
Old Feb 13, 2002 | 12:32 PM
vjo90RS8's Avatar
Car: 2002 Z28
Thats weird about the part number, when i ordered mine it didnt say anything about a water pump pulley. Just email them and they will clear everything up.
And yes, the delete pulley uses the same bolts as the compressor.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
gord327
Oct 3, 2015 01:25 PM
Damon
Sep 26, 2015 04:29 PM
HikoriYami
Sep 21, 2015 07:11 PM
