how do you relieve fuel press.
Old Feb 18, 2002 | 11:08 PM
CamaroEFI's Avatar
how do you relieve the fuel press. on a 91 TBI RS camaro. The hayes manual said to take the fuse out(labeled FP) but there is no fuse labeled that.
Old Feb 18, 2002 | 11:27 PM
Tas's Avatar
Tas
maybe undo the gas cap?
Old Feb 18, 2002 | 11:28 PM
CamaroEFI's Avatar
i didn't think that would relieve the press. to the pump. will it?
Old Feb 18, 2002 | 11:33 PM
91_hd's Avatar
You unplug the fuel pump relay, then start the car and let it run till it dies, this should only take about 3-5 seconds. I dont know where it is on an f body though, sorry.
Tas's Avatar
Tas
um. Maybe. Best thing is to get a Chiltons manual and find where that fuse is.
Old Feb 19, 2002 | 11:01 AM
CDN_87IROC's Avatar
What about if you cannot start the car?
I have the starter (and more) removed and need to release pressure. I have a TPI.
Old Feb 19, 2002 | 11:12 AM
steve8586iroc's Avatar
If you're working on a tbi car thats been sitting for a while without the ignition being turned on to the start position, just take the fuel line fittings lose. You won't have any fuel pressure because it will have bled off by then. Just through a rag underneth the area you're working on to catch any excess that might dribble out.
Old Feb 19, 2002 | 11:37 AM
vjo90RS8's Avatar
Car: 2002 Z28
I just remove the fuel cap and disconnect the battery whenever i adjust my fuel pressure.
Old Feb 19, 2002 | 02:47 PM
BlackBird305's Avatar
undo the gas cap and the fuel pump relay..the relay is located on the back of the tank...just crawl under the rear end of the car and look straight up on the back wall of the tank...there is a big weather pack connector, just unplug it....good luck
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
