MAXIMUM Lift with 64cc TBI Truck heads???
Old Feb 25, 2002 | 01:35 PM
TBIWorks's Avatar
those heads and flat top pistons.....how much valve clearance if I run a cam with lift in the low 500's on the exaust side? Also forgot, the block has been decked too, so it has maybe has 10 thousandths taken off.
Old Feb 25, 2002 | 04:28 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
.460 is the limit!!!!!!!! STOCK
Brian
Old Feb 26, 2002 | 09:19 AM
TBIWorks's Avatar
thanks, I guess I will have to figure something else out then.
Old Feb 26, 2002 | 09:29 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
The .450" lift limit doesn't have anything to do with piston to valve clearance. The heads themselves have to be modified to run more lift. Run a search on high lift with vortecs.
Old Feb 26, 2002 | 03:54 PM
TBIWorks's Avatar
what about if I run an LT1 cam, will that be okay?
Old Feb 26, 2002 | 04:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yeah it should be fine
Old Feb 28, 2002 | 02:24 PM
TBIWorks's Avatar
even with flat tops, the stock dished are quite a bit different. Also, what would limit the heads on lift, other than piston to valve clearance? Springs?
Old Feb 28, 2002 | 02:36 PM
Mark305TBI's Avatar
Valve guide to retainer clearance and springs.
Old Feb 28, 2002 | 02:38 PM
The only limit I can see is that the stock valve guides and springs will only haldle .450 to .460 lift I had mine taken down to haldle .550 lift. I run a lt4 cam with .480 lift on th e exhaust and have no problems.
Brian
Old Feb 28, 2002 | 04:52 PM
TBIWorks's Avatar
thanks guys, I guess I can use the ZZ3 cam after all, just need to have the shop check piston to valve clearance. The combo of stock heads, milled block, and flat top pistons makes me nervous ya know. I want to use a better cam than I have now, but I wan't sure on the lift issue.
xkingcodex
Feb 12, 2020 07:43 PM
junkcltr
Aug 2, 2019 11:12 PM
gta90
Sep 15, 2015 04:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
anesthes
Aug 8, 2015 09:37 PM
