Whichs heads are better: SR Torquers or Edelbrock 60cc
Old Feb 25, 2002 | 01:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I know that with the 60cc chambers on teh edelbrocks you will lose a tad bit of compression. Can that be made up with a thinner head gasket. Can the SR torquers be ported to match the flow of the Edelbrocks. Which one (when bolted one) would make more power? I see mustangs that use 64cc heads for the 5.0 and wonder why can't lo3 guys use the 60cc. I want the lightweight of the aluminum but HP is my greatest desire.
Old Feb 25, 2002 | 02:45 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
The 2cc won't make that much difference but the 2.02/1.60 valves of the edelbrock will cause problems with the cylinder walls in your 305.
Old Feb 25, 2002 | 08:08 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
What kind of problems will they cause? They clear the cylinder walls. NJspeeder has been running them for awhile. He's having no problems with them. Do you know someone who has had problems with them?
Old Feb 25, 2002 | 08:21 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Edelbrock states that you can maintain compression ratio on a 305 with these heads by using a smaller gasket.
I would think aluminum heads would always be better than iron cast ones.
Old Feb 25, 2002 | 10:25 PM
NJ SPEEDER's Avatar
this is a very common misconception. they will not hit anything and will require no notching or anything else, you just have to be slightly more conservative on your cam choices.
this is a good place to mention the great thermal efficiency debates iron heads are more thermally efficient and therefore transfer more heat energy to the piston, therfore transfering more power. aluminum heads are not as efficient in this way, so instead of transfering some of the energy they absorb it and disperse it into teh cooling system, but, since they are less efficient you can get away with a littel more timing.
this is the simplified version of the debate because i do not fully understand hwo dramatic teh differences are or can be. but i get the feeling both can produce similar power and the aluminum will knock 50lbs off your car.
later
tim
Old Feb 26, 2002 | 12:04 AM
Tas's Avatar
Tas
later
tim
Since the aluminum dissapates the heat better insted of containing it the way iron does, you can run more compression with the aluminum Heads. The extra heat that you'd have with the cast iron would predetonate causing baaad stuff whereas that won't happen as easily with the aluminum heads. The LT1 and LT4 take this a step further because the heads are cooled first by the reverse flow cooling method. So those can handle even more compression. Ligenfelter sells 12.0:1 compression Lt1/Lt4 heads that can run on pump gas. You'd be in a major pickle trying that with iron heads on a gen 1 block without jumping through some hoops to make it possible.
Old Feb 26, 2002 | 12:05 AM
JPrevost's Avatar
Car: 91 Red Sled
Tim, you beat me to it.
If you had 2 heads identical except one is iron, other is aluminum, the iron will product more power with the same compression ratio. The aluminum heads DO however, knock off 50lbs of the front end and you can (should) run higher compression to make up for the thermal efficiency of the chambers. It's funny how the LS1's have aluminum heads, make near 350hp at crank and get over 30 mpg on the highway! Of course that's with the 18^ heads and one totally differenct setup.
A good example might be the comparison between the Impala SS fron 94-96 with the iron head version of the Lt1. Those cars FLY!
Iron is also more forgiving with spark plug threads, head gaskets, and over all reliability. Although I wonder if they're more or less acceptable to cracking I would imagine so but not sure about that.
Anyways, go with iron for bang for buck, aluminum heads are just too darn expensive for a daily driver. Even Tim has his Cav to drive when his car is on jack stands!
Look at the Dart Iron Eagle heads. They make mad power and are very reasonably priced, a lot more bang from those heads than similar aluminum heads.
Tim, have you done any calculations that would tell you how close the valves are in the cylinder? I'd like to draft out an image in CAD that would show the exact location of the valves at max lift but I can't find any information regarding the edelbrock valve heights, centerlines and that crap.
If anybody has links to some small block chevy dimensions and head dimensions, please post em or e-mail me.
Old Feb 26, 2002 | 12:23 AM
Tas's Avatar
Tas
aluminm would warp before it cracked. There was a chick at school that warped her entire all aluminum inline 6. Lucky for her, her uncle is a BMW master mechanic.
Old Mar 2, 2002 | 12:58 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
You guys that are trying to choose between aluminum and iron should really look at some flow numbers of the heads for a good comparison. If you look at the Vortecs, they outflow almost EVERY iron AND aluminum head manufactured until you get up into the $1100+ price range (canfields, AFR's, etc.). Below .500 lift on the intake side, they outflow the Edelbrocks, Trick Flows, GM Phase II "Slow-Tie" heads. Really, guys, Vortecs are the way to go. On the exhaust side, they leave a little to be desired, but still are comparable to heads which cost more than twice as much. As soon as I get a few hundred bucks, I'm going to swap on a pair myself. For a comprehensive flow test of lots and lots of heads go to Chevy Hi performance's home page. In fact, I'll post a link here in a sec.
Old Mar 2, 2002 | 02:22 PM
super chevy's Avatar
How do you mod the EGR to work with the Vortecs and Vortec tbi intake?
SC
Old Mar 2, 2002 | 06:33 PM
NJ SPEEDER's Avatar
you have to tap into the exhaust and then tap into the the intake below the tb somewhere. there si a company that sells a kit to do it.
later
tim
Old Mar 2, 2002 | 06:37 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I saw a flow chart, and the Edelbrock performer kicked the vortecs but bad at any lift. This was not a performer center bolt head though. It doesn't flow as good with 60cc chambers. The performer center bolt heads flowed just slightly better then the vortecs.
Old Mar 2, 2002 | 06:38 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I would always choose iron for a street car. There's something about mating iron to aluminum that doesn't sit well with me. Also, threading a steel spark plug into an aluminum head makes me cringe. Again, you do loose a ton of wieght, but in a street car I don't see how that makes much of a difference since most will put 400 lbs of stereo equipment in the back
I would look around at the manufacturers websites. I know World Products lists the flow ratings for all their heads.
Old Mar 3, 2002 | 08:48 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
my subs/box/amp dont weigh 400 lbs and are easily removable for track use
Old Mar 3, 2002 | 11:41 PM
JRoy91RS's Avatar
Engine: 355
Uhh... no they don't, at least not according to this article:
javascriptpenWindow('http://www.chevyhiperformance.com/editorial/article_popup.jsp?id=41599&sidebar=1', 600, 400,'Sidebar')
Sure, the exhaust numbers are better, but the intake isn't.
Old Mar 4, 2002 | 12:25 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Hot Rod picked up 17 hp with the vortec heads (milled .040) and the Edelbrock Vortec manifold over the Torquers and their standard style manifold.
Question: is the bolt pattern the only difference in the vortecs? Are they the same size physically? I thought I read they were taller or something?
Old Mar 4, 2002 | 01:57 AM
Tas's Avatar
Tas
the intake ports are higher. Very tall and narrow. Mopar style.
Old Mar 4, 2002 | 09:33 AM
Vader's Avatar
...But do they outflow the ProAction Iron Lightning heads (at $249.00 each)?
Old Mar 4, 2002 | 10:22 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Hmm... interesting. Would there be any way to mate the Vortecs with a standard intake manifold, or would the ports on the manifold be too wide and not tall enough?
Old Mar 4, 2002 | 12:14 PM
JRoy91RS's Avatar
Engine: 355
No, you must mate the Vortecs to a vortec style manifold. That is the only thing that really sucks about going Vortec-- expensive intakes. Once you go Vortec, there really is no going back! This makes me think about bang for buck in that it may not be that great of a deal (Vortec) if you have to spend 200 bucks or more on an intake while standard SBC intakes are dirt cheap new and used.
Old Mar 4, 2002 | 01:04 PM
Tas's Avatar
Tas
people have tried and some have had the vortec ports peakign out from on top of the intake.
Old Mar 4, 2002 | 02:53 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Hm... poo. Luckily it seems that you can get pretty good money for vortecs, even used, so if you decide to go back to standard heads you can get most of your money back.
Old Mar 4, 2002 | 04:55 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
Here is the site I got my information at.
http://www.sallee-chevrolet.com/Fast...der_Heads.html
This site sells both types of heads.
The vortecs flowed better at .500 lift but since there only good for about .470 unmodified thats beside the point. I don't know where this site got these numbers, I only said that I saw a chart showing edelbrocks kicking vortec butt.
Old Mar 4, 2002 | 09:55 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Man those fast burns are pretty impressive. I wonder if we'll start seeing some serious build ups with them?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89-S-dime
Aug 12, 2015 11:57 AM
