anybody catch my new avitar. :)
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Its literally, a tiny peek at what my tbi design looks like. LOL. I'm still workin on getting the entire pod into solids in AutoCAD. Its a pain in the ****. Its a very detailed little peice.
Anyway....
Anyway....
You are designing your own throttle body?? I had thought of that as well, use the GM injector pod and carve a piece of aluminum out for 2" throtle bores etc. etc. I never really persued it cause I thought the price would be out of this world.
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Work on it is still coming slow huh? I know it ain't cheap.
I'm still interested (if) whenever you start making 'em. You have any specs on what the flow rate might possibly be?
I'm still interested (if) whenever you start making 'em. You have any specs on what the flow rate might possibly be? Trending Topics
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Yea snuf, I dont know if I can come up with the money, but if it'll flow better than the holley, use the stock gm pod, and be about $180 we'll see if I can scounge the money up.
work has essentially stopped. 500 is a little steep to throw at a prototype. I keep telling myself, one of these days ill make one out of Oak or something and test it a bit., but i havent yet.
yes. 4 bolt carb adapter. any style manifold.
flow, well, whatever you think 2 2.25 inch or 2 2" bores would flow, with that extra clearance around the injectors, flow would increase at an increased rate if you know what i mean, not like just openeing up bores, but openening and unrestricting because more space around injector pod is open. only thing i am worried about is if velocity were to slow too much. doubt it though
, if the engine was large enough.
i will make one someday. good luck copying that little pic, if you can, make your own LOL.
, if the engine was large enough. i will make one someday. good luck copying that little pic, if you can, make your own LOL.
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by 1991 RS 305
brodyscamaro, go to top of page click on "User CP", then click on "Edit Options". You'll see "changd Avitar" towards the bottom
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
What were you thinking? :lala:
