tas/snuffy/jprevost...stock tb flow numbers???
Old Mar 6, 2002 | 04:48 PM
NJ SPEEDER's Avatar
hey guys,
i am sure at least on of you guys has it written down someplace. i was wonderring if anyoen ahd ever flowed a stock TB, as cast, no ultimate mods??? how about with ultimate mods???? i am working on my next great evil plan to take tbi where no one has taken it before and i can't find the @#%&*# numbers i need. lol
thanks
tim
Old Mar 6, 2002 | 05:50 PM
iroc22's Avatar
I've seen tests where it flows 520cfm.
Old Mar 6, 2002 | 07:31 PM
Tas's Avatar
Tas
Re: tas/snuffy/jprevost...stock tb flow numbers???
Originally posted by NJ SPEEDER
hey guys,
thanks
tim
you car correct sir :lala:
https://www.thirdgen.org/techbb2/sho...threadid=40439
Old Mar 6, 2002 | 07:36 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
when you say bored out stocker flows 585 cfm, do you mean ultimate tb mods or actually boring it out to 48mm or whatever?
Old Mar 6, 2002 | 07:46 PM
Tas's Avatar
Tas
whatever size turbo city bores them out to along with their shaved throttle bades and other mods. http://www.turbocity.com/TBIPowerMain.htm
Old Mar 6, 2002 | 08:33 PM
steve8586iroc's Avatar
What do you have up your sleeve NJ. You know we all can keep a secret.
Steve
Old Mar 6, 2002 | 08:45 PM
NJ SPEEDER's Avatar
Steve
hehehehehehehehehehehehehe..........you'll see
i will say two things, it ain't what you are all thinking and it will be TBI
other info to follow once the build up starts.
later
tim
Old Mar 6, 2002 | 08:46 PM
NJ SPEEDER's Avatar
is that with the injector tower in place????? or is this a number for just what the body itself is capable of??????
thanks
tim
Old Mar 6, 2002 | 08:55 PM
Nitroburn's Avatar
later
tim
Dude... you're killing us!!!! About some more hints... Either that or up the #$%^ up and get the project started so that you can give us some details!!! :rockon:
Old Mar 6, 2002 | 08:58 PM
NJ SPEEDER's Avatar
another hint.....hmmmmm.....ok , it is gonna make my car go really really fast i am gonna rebuild the whole car, every nut and bolt is coming off at the end of the season for a complete resto.
it is an all out, no holds barred, TBI build up
:lala:
later
tim
Old Mar 6, 2002 | 09:02 PM
Your not going to change your name to NJpufilus are you?
Now your into tbi designing and you are going to make a better tbi right?
Trying to figure out the max. amount of nox you can run on one 1/4mi pass that will only blow the engine at the end of the track?
Going to convert a holley fourbarrel carb over to tbi?
I'm sure the list will continue to grow.
Steve
Old Mar 6, 2002 | 09:08 PM
Tas's Avatar
Tas
less talk, more go.
Old Mar 6, 2002 | 09:22 PM
iroc22's Avatar
thanks
tim
That's with the injector pods in place. Pretty impressive hey?
Old Mar 7, 2002 | 12:51 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I seriously doubt that it'll flow 520cfm with the injector towers in place. Holley rates their 1.68" throttle body at 400cfm. Another bad thing about this flow rate debate is that these throttle bodies are flow tested at a 3" pressure drop. If you think about it that way, the Holley 670cfm throttle body doesn't even flow as much (in actuality) as a 650cfm double pumper.
Old Mar 7, 2002 | 08:35 AM
TBIWorks's Avatar
All the #'s I've heard are pretty accurate. I have heard 525 just open bore bench flow. I hope that it will flow at least 500 with the injector pod in place though. This is only what I have heard. Hey incidently has anyone tried turbo city's modified TBI? I wonder if it would be a waste of money to get one of those instead of the holley or a 454 TBI?
Old Mar 7, 2002 | 01:41 PM
JPrevost's Avatar
Car: 91 Red Sled
So if 1 TBI isn't enough, go with 2, geeze, what's the big deal?
If the holley 670 doesn't flow as much as a 650 double pumper then tell my car that. Considering a 600 or even a 625cfm carb is usually plenty for 400hp, what's the problem?
BTW, I think I know what NJ is doing and it isn't with a 305, more cubes is my only hint and the intake is pretty weird, definatly a first.
Old Mar 7, 2002 | 04:25 PM
i dont think 600 cfm is enough for 400HP
Old Mar 7, 2002 | 04:47 PM
NJ SPEEDER's Avatar
600cfm is plenty for 400hp. remeber, the formula's for determining how much air flow you really need have little to do with your hp goal. they have more to do with how many cubes you have and how many rpm you intend to spin. you are only looking to match the cfm number to the air supply needs of the engien to take so many breaths so quickly.
the most common formula i have found is:
(CID*Max. RPM)/3456= CFM Required
example:
(350*6000)/3456= 607cfm
you can certainly make 400hp with a small block below 6000rpm. the thing to remeber is that this is an approx of the min. needed, so yes, more cfm may benfit the motor.
if you really wanna see what you can do with small carb/cfm motors i woudl suggest going to a local short track, a lot of those classes have carb restrictions that sound rediculous, like a 400cfm 2 barrel class i read about, but they still make a lot of power(the 400cfm guys were making in the 340's at the crank!)
later
tim
Old Mar 7, 2002 | 05:09 PM
JPrevost's Avatar
Car: 91 Red Sled
You can't compare cfm of a carb to cfm of a TBI just like you can't compare the cfm flow of a TB on TPI to a carb! They're completely different intake systems that accomplish the same thing but go about doing it differently. Look at the EFI they have on that 502 motor in GM performance crate engines, it's got a stock L98 TB, the reason it can use that small of a TB is the design of the rest of the intake. It's got a huge area to draw lots of air and so it doesn't need a massive throttle body. Hence the explination for why a huge TB almost never makes you faster unless you have a small intake on a large engine.
TBI is more like a carb but it doesn't rely on the design of the actual throttle blades to atomize the fuel at WOT! If you had a 2" TBI, a large intake manifold like the victor jr and a spacer for the TB, you give the engine a very large area to draw pre-mixed air and fuel. This is why cfm ratings don't make or break an engines output, it's just tuning with spacers, intake design, cam, displacement, the WHOLE SHE BANG!
Carb cfm ratings are more important that EFI for street driven reasons. A huge carb at low rpm is going to be very inconsistant with fuel delivery, EFI doesn't have that problem. In other words, you could tune a winpy motor with EFI with dual 1000cfm TB and 16 p&h injectors...but you don't need all that. It won't hurt anything but it's a waste of money and nothing hurts more than looking faster than you really are. In the same boat, you could tune an EFI system with a huge intake and a small throttle body, it would just require a different approach to tuning and probably sacrifice a little bit of peak power vs a smooth torque curve. Something to that order.
I don't have any doubts that the holley 2" 670 unit will flow enough air for 420hp, I just need to make sure the fuel delivery and timing is tuned and that I bring it to get dynoed .
Old Mar 7, 2002 | 11:33 PM
NJ SPEEDER's Avatar
hehehehehehehehehe :lala:
this motor will be built this summer. it won't go in the car until at least mid winter. but i will be sure to vid tape the first for ya
later
tim
Old Mar 8, 2002 | 12:19 AM
iroc22's Avatar
example:
And remember that most street strip engines will only produce 95% VE so they wont even need the 607 cfm.
Old Mar 8, 2002 | 12:39 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I know what motor he is building but I can't devulge anything. He'd probably stop talking to me and thus giving me TBI advice.
Old Mar 8, 2002 | 04:07 PM
NJ SPEEDER's Avatar
since everyone is soooo curious i got a deal for ya.
i am in the final stages of plannign this thing. once i figure out the final induction plans, and have everything collected, i will post the whole build up plan. i will also post up the numbers from desk top dyno that i will run for the combo. unfortunately, dd2000 does nto comensate a little extra power that it shoudl make because it is fuel injected, but it should be a good estimate.
'til then, keep wondering
:lala:
later
tim
Old Mar 10, 2002 | 06:26 PM
AdioSS's Avatar
Car: 96 Impala SS
My guess is a big block with dual TBIs. I hope this is it because it would make my future plans much easier.
Old Mar 10, 2002 | 06:51 PM
Keith5's Avatar
Car: C1500
I'd say 383+ cubic inch short block, using the edelbrock heads you have now.
Old Mar 10, 2002 | 08:27 PM
NJ SPEEDER's Avatar
not a big block, not using my edelbrock heads....
this is kinda fun...hehe
i ran a base line of the set up on desktop dyno tonight. now i am really looking forward to building this engine
hehe:lala:
later
tim
Old Mar 10, 2002 | 09:03 PM
Nitroburn's Avatar
Naw.. I think it'll be a SBC with some kind of forced induction (either a blower or turbos). I'm guesiing it would be a roots-type blower since he give us a hint..... the software he was using does not figure in with FI (only carbs?) Thus, seeing that FI is not common on roots-type blowers (gerneral speaking), maybe that's the route his taking.
I would love to see a SBC with a 6-71 and dual TBIs!!! Now that's my future plans for my bird (already got the hood for it!!
Later,
Mike
Old Mar 10, 2002 | 09:14 PM
like a bunch of little kids trying to guess where their daddy is taking them
Old Mar 10, 2002 | 09:19 PM
NJ SPEEDER's Avatar
the motor will be N/A
later
tim
Old Mar 10, 2002 | 09:22 PM
Nitroburn's Avatar
Easy... I'm a daddy of 5!!! And I get just excited over this stuff as much as a kiddie in a candy store the size of Texas!!! :sillylol:
Old Mar 10, 2002 | 09:23 PM
Nitroburn's Avatar
Dang... and here I though you were gonna pull a rabbit out of your rear or something.
Old Mar 10, 2002 | 09:25 PM
no flame intended just my observation
Old Mar 10, 2002 | 09:41 PM
Nitroburn's Avatar
None taken at all!!! Just having some fun this evening!
Old Mar 10, 2002 | 10:26 PM
JPrevost's Avatar
Car: 91 Red Sled
I think if I were Tim I'd do something like a 400 small block with a
Offenhauser/Edelbrock/GM cross-ram intake and dual stock 500cfm TB units with 55# injectors and a custom eprom and a trick air cleaner setup.
Yeah, that's what I'd do if I had the money.
Either that or build a 454 small block and use the same intake.
Check out this link to the chevy cross-fire intake and how they modified it to accept a single carb. If you had a big enough engine and the tinker time you could just get 2 pairs of vette/f-body cross-fire TB units and use 4 single barrel TBIs but that's a mess with the fuel line routing so unless you've got lots of time and are good at fabrication, I wouldn't attempt it.
Old Mar 10, 2002 | 10:54 PM
NJ SPEEDER's Avatar
lol
ok ok, i'll post teh plan.
check out my new thread
later
tim
Old Mar 10, 2002 | 10:56 PM
iroc22's Avatar
man that would be awesome to run a Fuel Injected cross ram.
PurelyPMD
May 5, 2016 04:57 PM
69GTOby
Apr 18, 2016 02:34 PM
84redta
Sep 19, 2015 09:58 AM
Springster
Sep 13, 2015 01:38 PM
blackandblue02
Sep 10, 2015 08:19 PM
