what cap, rotor, and wires to get?
Old Mar 19, 2002 | 08:59 PM
Nasty_Bird_'90's Avatar
getting ready to swap all this stuff, and i was wondering what you guys have to say about it. i'm getting ready to do cap, rotor, wires, and coil. probably all MSD because its pretty red! thanx
Old Mar 19, 2002 | 09:46 PM
firbird's Avatar
well i prefer msd over accel because i hate there wires, they dont really click in place and i have to push the cord back in the boot every so often
Old Mar 19, 2002 | 10:20 PM
Chevyman69's Avatar
My MSD wires melted internally. I had the 8 mm ones and they balloned up to twice their normal size and melted along my valve covers. I usually advocate for MSD and their usual qulity but not this time. I run GM wires now and Acell Cap and rotor.
Old Mar 21, 2002 | 06:58 AM
RS91's Avatar
My MSD Set-up worked fine with me....
Old Mar 21, 2002 | 09:28 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I went with the MSD 8.5mm Superconducters, MSD Cap/Rotor, and MSD Blaster Coil and I am very happy with the results that I have had them for a year of driving.
Old Mar 21, 2002 | 03:52 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i run accel cap n rotor,accel coil, msd 6a box and msd 8.5 wires with accel shorty plugs......no complaints.....just make sure you get all 90 degree boots if you have headers
Old Mar 21, 2002 | 08:25 PM
iroc22's Avatar
I have the MSD cap and rotor which has worked well and looked fine when I pulled it off; I ran it for a year. I dont really like the Accel wires cause they burnt prematurely before. Right now I am running Taylor wires, which have worked excellent. They have a higher resistance though than the MSDs but they wont burn, and I like that.
Old Mar 22, 2002 | 10:22 AM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I HAVEN'T HEARD TOO MUCH ABOUT MOROSO BLUE MAX WIRES I KNOW SOME GUYS WHO RUN THEM AND LIKE THEM WHAT DO YOU GUYS THINK?
Old Mar 22, 2002 | 11:15 AM
CamaroBoy88's Avatar
You have to watch and make sure your are getting suppression wires. You can't run a spiral core. MSD are suppression at a low resistance. Other wise ACDelco p/n 618V are 8mm wires with 90 degree spark plug boots. I used the Delco due to the price and Mr Gasket makes excellent wire dividers that bolt to the two middle (center bolt) bolts holding valve covers on. However, I think they might be on back order currently. It took a couple weeks to get mine.
Old Mar 22, 2002 | 12:54 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Has anyone seen or have that clear cap?
Old Mar 24, 2002 | 02:50 PM
thanx for the info. i went ahead and ordered the 8.5mm superconductors, MSD cap and rotor, and when another paycheck comes along, the 6A box with blaster 2 coil. thanx
Old Mar 24, 2002 | 03:35 PM
RS91's Avatar
Alright Nasty. Let me know how it runs with Ignition 6A Box.
Old Mar 24, 2002 | 05:20 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Ive got Moroso Blue Max Spiral Core wires, they work great.
Andrew
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Winchester1094
Aug 18, 2015 10:23 AM
86IROC112
Aug 17, 2015 07:57 PM
