Need some help
Old Mar 24, 2002 | 04:20 PM
NXS055's Avatar
Need some help
ok, I want an LT1 cam and I have money for it.
If anyone has one or would like to point me in the right direction please do so, I've been to camaroz28.com with no luck.
thanks
Old Mar 24, 2002 | 07:04 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
make sure you have about $300. Thats what it takes to do the swap regardless of how much you spent on the cam
Just keep checking the classified board, do it every few hours, you gotta be quick. You can check Ebay if you want also.
Old Mar 25, 2002 | 03:02 PM
NXS055's Avatar
well say 50 for the cam (i found one)
whats gonna cost me 250 dollars???
Old Mar 25, 2002 | 07:51 PM
Sonar_un's Avatar
Car: '86 T/A
all the extra parts, gaskets, lubricants, fixing whatever you broke, etc..etc..
Old Mar 25, 2002 | 10:48 PM
iroc22's Avatar
Be prepared for a lot of work.
Old Mar 26, 2002 | 07:21 AM
NXS055's Avatar
oh ok, well hopefully I won't break much
has anyone heard about the how to step by step guide we were supposed to be getting about this???
thanks
Old Mar 26, 2002 | 08:11 AM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
when you're ready to do it and u have the cam and everything i will write out directions 4 u if noone has them somewhere else. i did it when i rebuilt the engine and 500 miles after i had the engine in the car..its not too bad either.. just time comsuming...almost an 8 hour job.
Old Mar 26, 2002 | 10:18 AM
NXS055's Avatar
i would forever be grateful
I'm new to all of this stuff, this will be the first time i've been inside a motor except for a Kawasaki 80cc dirt bike (not quite the same) hahaha
thanks man
I appreciate it
Old Mar 26, 2002 | 02:53 PM
Sonar_un's Avatar
Car: '86 T/A
8 hours?! Man I wish, took me 7 days!
Well.. not full days, and deffinitely not every day But still.. at least 48 hours were spent on it, if not more.
Old Mar 26, 2002 | 06:20 PM
Engine: 5.7L
i dunno man..7 days is a long time...i take it was ur first time doing a cam swap? i did my friend's 95 TA cam swap in about 13 hrs... took a bit to figure out how to get the damn intake manifold off.... lots of things had to come out... on the tbi cars it isnt hard at all. i did one cam change when i took the engine out of the car and rebuilt it... then a while later i changed it with the engine in the car... 48 hrs? no offense but im glad ur not my mechanic charging by the hour
Old Mar 27, 2002 | 10:13 AM
NXS055's Avatar
well being the first time i've been into one I'm just going to take my time and try to learn while i'm doing it. maybe next time It won't take so long, but I'm not in any hurry to get it done. I'm going to do it in my aunts basement (heated, dry, etc) and I'm just going to work on it when I can. I still have my other camaro to ride so Its all good...
and I would love that step by step, or at least a decent rundown of whats gotta be done and when, it doesn't need to be a bolt by bolt instruction manual, but maybe just a take this off, then this, then this, then go beat head against wall when this won't come off... just something like that... hahahahh
thanks a lot guys, your all very helpful
Cody
Old Mar 27, 2002 | 12:09 PM
Sonar_un's Avatar
Car: '86 T/A
It took me that long because that was the first time I have ever touched an engine... EVER
I double checked everything I did, made sure it was done completely right, and guess what, everything does work, perfectly, the first time
But the next time I do it, it probabally won't take me long at all. I will know exactly what I will need to get and all that other stuff. It shouldn't be as large of an ordeal.
Old Mar 27, 2002 | 05:55 PM
Engine: 5.7L
hey ..got some advice for cam swappers. change the pushrods too!!!! the factory ones are weak. i bent 2 of mine at the dyno.
Old Mar 27, 2002 | 11:57 PM
NXS055's Avatar
you said that next time you'll know everything that you'll need???
how about helping a bud out with a list???
ok, what valve springs should I get? Cost??
what pushrods?? cost??
guys I really appreciate your help on this. Maybe one day you'll have a question I an answer, thats a big maybe though... haha
thanks guys.. I'm so excited :lala:
by the way, how much is a new LT4 cam and is it worth its extra price??? also, if I wanted to check on that at a parts store how would I tell them to look it up??? what did it come in???
thanks
Cody
Old Mar 28, 2002 | 08:40 AM
Engine: 5.7L
im not sure any car came with an LT4 cam...but then again i dont know much about 4th gens.
Old Mar 28, 2002 | 02:57 PM
iroc22's Avatar
1996 Corvettes with the 350 LT4 got the LT4 camshaft
and also the 1997 SLP special LT4 SS Camaro got the cam.
Old Mar 28, 2002 | 05:52 PM
DM91RS's Avatar
Car: 91 RS
Go to WWW.paceparts.com and look under camshafts for LT4 stock cam....around $140
Old Mar 29, 2002 | 02:54 AM
Jza's Avatar
Jza
He's already made that list. Check it out. https://www.thirdgen.org/techbb2/sho...threadid=92450
Old Mar 29, 2002 | 11:04 AM
NXS055's Avatar
thanks jza, I had never saw that post.
ok so bout 400 bucks should do it.
ok, what about valve train work. every time I mention doing this to anyone that isn't part of this board they start telling me all of the stuff I'm going to have to do with the valve train, springs, rods, valves, bla, bla, bla
needed list as of now:
cam
tools
gaskets
liquids ie: oil, antifreeze, etc.
time
is there anything I need to add to this list, such as valve springs? push rods? is any of this necessary, or just preferable. Am I going to be replacing it in a month or two anyway cuz it breaks or is it something that doesn't really need to be done?
ok, and if there is something that NEEDS to be replaced, what are your suggestions, and what can I expect to pay? I'm sorry to keep buggin you guys so much, but there is so much to think about and I'd like to have everything I need together before I start this, I dont' want to have my car down for too long and I don't have the money to just go out and buy something just at any time.
thanks guys
I appreciate it a lot
Cody
Old Mar 29, 2002 | 05:48 PM
iroc22's Avatar
You need to replace your valve springs for sure, but the pushrods arent necessary.
Old Apr 2, 2002 | 08:55 AM
NXS055's Avatar
ok, what valve springs would you recommend, and how do you change them?? take head off? air compressor and pump up the chamber?? isn't there an easier way??? please??? hahaha
thanks
Old Apr 2, 2002 | 04:10 PM
iroc22's Avatar
I got the 983-kit from comp cams which is the 1.25" spring. Yeah you need to pump up the cylinders so the valves dont drop down.
Old Apr 3, 2002 | 02:16 AM
Jza's Avatar
Jza
Pressurizing the cylinder IS the easy way. The next easiest is to feed a nylon cord into the combustion chamber via the spark plug hole to hold up the valve. The most pita way is to remove the head and do it on the bench. Some people get away with just bringing the piston up to TDC, but I've never tried it that way.
Old Apr 3, 2002 | 07:34 AM
NXS055's Avatar
dam that sucks.
I'm trying to find a good deal on getting my heads ported so if I do that then I'll take them off anyway so that solves the problem. but if not, then I guess I'll pump up the chamber. doesn't sound like much fun to me.
how much did those springs set you back...
