Think i found my problem.
Old Apr 10, 2002 | 09:45 AM
TEXAS89RS's Avatar
I finally did what i should have done to begin with. i pull up the trouble codes in my rs. and got a code 32. on my lo3 that is something with the egr system. i check all the hoses and they are all fine. i checked the valve and it is stuck! could this be the cause of the odor coming from my car??
Old Apr 10, 2002 | 09:51 AM
MX265
Guest
Posts: n/a
I had a bad fuel smell after driving it coming from my 89 IROC. It is currently in the shop right now. They found a stuck EGR as well, so it could very well be your problem. I'll find out in a few days if it fixed it or not.
Old Apr 10, 2002 | 12:44 PM
TEXAS89RS's Avatar
thanks let me know it that was the fix!
Old Apr 10, 2002 | 08:20 PM
TBI305Camaro's Avatar
very easy fix just need an open end wrench and 20 minutes of your time
Old Apr 11, 2002 | 09:05 AM
TEXAS89RS's Avatar
but do you think that will get rid of the stench???
Old Apr 11, 2002 | 01:37 PM
91Firecrow305TBI's Avatar
All the more reason not to use egr. Hehehe. I went through 3 of those damn valves in 10k miles, and finally I had enough and used a different intake manifold with no egr. Then again, I am not concerned about emissions.
Clint
Old Apr 19, 2002 | 12:29 PM
TEXAS89RS's Avatar
hey mx265,
did you find out if the egr valve was the cause of the odor in your car?
Old Apr 19, 2002 | 09:21 PM
Dex's Avatar
Dex
well my egr was stuck and i never had an oder i also dont have a cat on my car sounds like your needs replaced:lala:
Old Apr 21, 2002 | 02:04 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Supposedly, if the EGR is stuck or if your cat is going bad there will be a smell similar to rotten eggs out of the exhaust.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
rudolphschenker
Sep 4, 2015 02:41 AM
