Rubbing sound On Wheels
Old Apr 14, 2002 | 07:36 PM
iroc_cragg's Avatar
Hey
When I drive my car it sounds like somthing is rubbing against the tire or somthing. I looked and it doesnt look like anything is there. What should I do because its annoying.
Thanks alot
http://camaroz28.cardomain.com/id/56424
Old Apr 14, 2002 | 09:31 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You didn't happen to rotate the rear wheels to the front did you?
Old Apr 14, 2002 | 10:41 PM
iroc_cragg's Avatar
nope. the front wheels are on the front and the rear wheels are on the back. Im not sure what it is. I think that it might be that plastic peice where the fenders are to protect the engine from getting any rocks or anything in there. Thats what it rubbing maybe. Should I take the wheel off and check.
Old Apr 14, 2002 | 10:46 PM
Car: 99 Formula
Axle/Gears: 342
Sounds like your describing your air dam, that's to help with cooling.
Old Apr 14, 2002 | 10:50 PM
iroc_cragg's Avatar
no im talking about the plastic peice inside the wheel wells. Do u know what im talking about or not.
Its not the peice at the bottom of the car.
Old Apr 14, 2002 | 10:51 PM
Car: 99 Formula
Axle/Gears: 342
Nope sorry.
Old Apr 14, 2002 | 10:55 PM
iroc_cragg's Avatar
oh ok
well on my car there is these plasic peices inside the wheel wells that protect the engine from being hit from rocks and stuff. I think thats what is making the noises.
Old Apr 15, 2002 | 12:12 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
oh ok
All Camaros have wheel wells.
I've heard that a particular suspension piece can cause a sound like the tires rubbing when you turn the front wheels almost to their end play. Maybe someone familiar with the problem can help. I think it is a sign that the part is getting worn.
Old Apr 15, 2002 | 06:01 PM
iroc_cragg's Avatar
nevermind then. u guys must not have the same things
Old Apr 15, 2002 | 06:10 PM
Blackened's Avatar
So if THAT piece rubs on the wheel why dont you cut it off, bend it out of the way, burn it off, see WHY it's rubbing and attempt to affix it back somehow, etc etc ... ?!??? Do you want us to go to your house and do it for you ? lol
Old Apr 16, 2002 | 11:18 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
He must be talking about the inner fender skirts.
In my experience, if it sounds like it's rubbing there, it probably is. Pull the wheel off and look for evidence of it rubbing. A lot of times you can use a heat gun to "re mold" the plastic away from the tire.
Old Apr 16, 2002 | 07:25 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
I am familiar with what you are talking about, but there was a distinct mark on the inner plastic fender well. Mine was hosed due to the pervious owner's improper installation of a bra.
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Fronzizzle
Mar 18, 2019 08:29 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
B_Dubya
Aug 26, 2015 05:09 PM
