View Poll Results: Where should I put my charcoal canister?
Mount it to the winshield washer fluid resevoir.
0%
Cut the area it's in already, and lower it.
16.67%
Toss it!
83.33%
Other... (Please specify)
0%
Voters: 6. You may not vote on this poll
Charcoal Canister Move...
I am sick of all my under hood clutter!!!!
But I am doing things about it. The cruise control- Gone! But I need the charcoal canister. (Right?) Where do I put it? It cant go where it is, passenger side battery area, because I am going to make a fiberglass air box.
I named some suggestions but you guys feel free to add more...
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Well if you keep it, make sure you mout it just how it was from factory. If ya mount it on its side or somethin, it wont work.
Transmission: A4
i recently did an engine swap and removed my AIR pump so i am ditching the canister as well. make sure that you plug the hole on the throttle body that the plastic line use to go to. also, do not plug the fuel line vent hose. just leave it alone. it should make a bad fuel smell but if it bothers you then take the whole fuel vent line out and let the tank vent from above the rear end. dont toss it if you need emission testing.
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Can't you just connect the vapor line from the carb to the line on the charcoal canister that goes back to the tank??
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i removed the washer bottle, as for the vapor can, i asked slp they said leave that and the purge valve alone............
Well considering that the car is going in for emmisions in the summer, I think that I am going to mive it 4 inches inwars to make way for the filter box... Make a bracket for it to reat on, but the first chance I get, I am tossing it...
