My car gets hot at idle
Old Apr 17, 2002 | 04:33 PM
cobrakiller1989's Avatar
i have dual fans running all of the time. a new radiator, new 180 degree thermostat. 2 year old water pump...the car runs fine while im driving on the highway or atleast at a decent speed, but as soon as i get into stop and go traffic with the A/C on the temp just creeps up on me. i usually turn off the A/C and put the windows down when the temp starts to climb above 220. any suggestions? im gonna change my coolant tomorrow and use a 50/50 mix and add a bottle of water wetter
Old Apr 17, 2002 | 04:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Make sure you're not running lean or you don't have any exhaust clogging.
Old Apr 17, 2002 | 05:02 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
may not be the prob but look in between the radiator and the condensor for obstructions. leaves plastic bags, etc.... i had plastic bag and plenthora of leaves stuck in there. good luck
Old Apr 17, 2002 | 10:46 PM
i cleaned out some leaves behind the condenser. there was a pretty good bit back there. but still it is cool out tonight and all and the temp still goes up on it. i know im not lean, im actually a little rich. im gonna see if maybe my cat is getting clogged or something too, maybe that could have something to do with it as mark said exhaust clog.
thanks for the help, anyone else have any ideas
Old Apr 17, 2002 | 11:19 PM
BTW, i know this may be a long shot here....but sautrday i changed my oil and didnt realize it, but i bought mobil 1 synthetic blend, rather than the synthetic i normally use. i really doubt it, but could this have anything to do with it? im just trying to think of any possibility and this saturday is when it started getting warmer
Old Apr 17, 2002 | 11:21 PM
87transam5.7tpi's Avatar
what temp does your fans turn on? and also are you runing antifreeze or water? I do like 30% antifreeze and 70% water in the summer, then like 60% 40% in the winter. that makes a difference.
Old Apr 17, 2002 | 11:25 PM
i have dual fans that are running all of the time and running strong. i have about a 60/40 mix (60=water)
Old Apr 17, 2002 | 11:35 PM
Car: 1988 IROC-Z
one thing i might suspect would be a bad temp sender for your gauge. or perhaps the gauge is inaccurate? did you flush the entire system at the time that you replaced the radiator? what kind of water pump? autozone? i have had fairly new cheapo water pumps go out within a year or so. hoses in ok shape? water level is ok? in other words you don't need to water every other day? just shooting some ideas around. good luck
Old Apr 17, 2002 | 11:40 PM
i know the gauge is accurate(scan tool verified that). the water pump is a cheapo and im gonna replace it with an aluminum pump and also do a coolant flush.
thanks again for all of the ideas
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
