EGR Solenoid Diagnosing Question
Old Apr 23, 2002 | 08:59 PM
ORAY777's Avatar
In checking the wiring going to the EGR Solenoid i'm supposed to take a test light across the two terminals to the solenoid. Are the two wires going to the solenoid both positive wires? Or is one negative and one positive? It's my first time to test the wiring like this with a test light and i don't want to screw up my computer in the process so i want to do it right the first time. Also in checking the resistance of the EGR Solenoid what are the spec range in ohms for it to still be good.
Old Apr 24, 2002 | 09:39 AM
Vader's Avatar
ORAY,
A test light may not be very useful to diagnose the solenoid. Test the solenoid coil resistance with an ohmmeter. You should get something like 30-60 ohms. Connecting a test light while the EGR is connected and the engine is operating may indicate the pulses to the EGR solenoid from the ECM, or may not.
Old Jan 10, 2012 | 08:11 PM
goliath88's Avatar
Car: 88 firebird convertible
Engine: 305 tbi v8
Re: EGR Solenoid Diagnosing Question
30 to 60 ohms while its running?? or with the ignition on only?? not in volts??
jklein337
Sep 19, 2018 06:23 PM
Out-Cast
Sep 3, 2015 09:05 PM
fasteddi
Sep 2, 2015 10:29 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
