temperature
Old Apr 30, 2002 | 12:30 PM
theCure's Avatar
Car: Looking
temperature
i have a 91 camaro z28 conv. its a 305 tpi / auto
the problem is, if it is a problem, going down the highway the temp stays around 150 to 175 (exactly between the 100 and 220 temps) and as soon as i get in a city, and i stop at like 2 red lights the temp shoots up to 220 very quick. i found a little hole about the size of a needle in the top front of my radiator. so i put some radiator sealant in and put more water in and the temp is still doing the same thing. its this temp normal? i just bought the car. i owned a 92 camaro rs and the temp never got that high so quick like that. what do ya'll think? is it normal? or am i over-reacting?
Old Apr 30, 2002 | 01:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
220* is normal for these cars, the fans don't come on till then, does it go any higher? Though it sounds like you might have a faulty temp gauge, are you running the stock stat, that is 195* so you're car shouldn't run colder than that once the car heats up.
Old Apr 30, 2002 | 01:17 PM
theCure's Avatar
Car: Looking
its only went over 220 when the car is idling for a few minutes, but i guess thats correct then. i'm gonna get me a lower temp gauge and hook me up a switch so the fan will turn on sooner. i'd just rather be safe than sorry. but sounds like everything is normal then. so thanks
Old Apr 30, 2002 | 01:21 PM
85wilrocu's Avatar
Big Mistake, putting in the sealant. Starts to clog radiator.
Old Apr 30, 2002 | 01:34 PM
theCure's Avatar
Car: Looking
my uncle said something like that after i had did it, b-cuz i didn't know that i shouldn't put it in there. i thought that was what it was for, but how do i go about fixing that? drain radiator? replace it or what? it has a very small fixable hole
Old Apr 30, 2002 | 01:43 PM
85wilrocu's Avatar
Don't freak out! How is the condition of the radiator? Just drain it, if the water is bad, don't if you don't need to!
Old Apr 30, 2002 | 01:48 PM
theCure's Avatar
Car: Looking
the condition of the radiator is very good, other than that tiny little pin hole, the radiator looks brand new. i guess i can drain the water and put some new antifreeze and water in it and put some jb weld on the hole. think that would work?
Old Apr 30, 2002 | 01:53 PM
85wilrocu's Avatar
Well is the leak fix? If so leave it! And just let it be.
If not drain it and fix the leak and refill! Oh and a bottle of wetter fluid(I think thats what its called) pink stuff!
Old Apr 30, 2002 | 01:55 PM
theCure's Avatar
Car: Looking
i'm gonna check in a few minutes to see if its leaked any, if not then i'll leave it alone. and thanks
Old Apr 30, 2002 | 01:57 PM
85wilrocu's Avatar
No problem, thats what everyone is here for!
db057
Jan 10, 2020 08:55 PM
ironbmt
Sep 27, 2015 06:00 AM
Logan Bryant
Sep 23, 2015 06:51 AM
BWilcox
Sep 20, 2015 12:19 PM
