Is this normal
Old May 1, 2002 | 09:15 PM
SlowStangEater's Avatar
Is this normal
My battery gage sits around 13..............But when I turn on the A/C it dives straight down to 8.5 or so................Is that Normal?
Old May 1, 2002 | 09:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It shouldn't drop that low, though the gauges in our cars are known not to be accurate. I would say as long as all your accessories work fine and light don't dim, then there's nothing to worry about.
Old May 1, 2002 | 09:44 PM
Occasionally they do dim and when my fan kicks on the rpms drop really low.............Once it died on me cuz it dropped so low....
Old May 1, 2002 | 09:48 PM
breathment's Avatar
for a thirdgen yes.. which isn't a good thing. our alternators are like 105 AMPS, i can make my voltage go down to 9 jsut by turning on the lights and rear defogger, with no a\c on.. imagin how low it gets at night when the windows are fogged with the lights on... try getting a higher AMP alternator, i don't know where though...
Old May 1, 2002 | 09:54 PM
Car: 99 Formula
Axle/Gears: 342
105 really?? Crap and I thought I got a good one from summit 100amp.
Old May 1, 2002 | 10:01 PM
If I have my Amp hooked to the battery..............It doesnt drain it does it?
Old May 1, 2002 | 10:07 PM
Car: 99 Formula
Axle/Gears: 342
Only when it's turned on, I would think or using your stereo.
Old May 1, 2002 | 10:14 PM
Thats what I thought ..........Just checking. you know all the starting problems Im having
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
