heads
Tons.
The 416 casting 85-86 TPI 305, are quite a good head. The 87-92 081 casting are the same runners and slightly improved combustion chambers, but overall the same head.
The 88-95 187 casting TBI head, is a torque producing head that has cast-in swirls and valve shrouds to build low speed torque. Very bad for high RPM's. They typically can only feed a 305 to max 5000rpm and a 350 to about 4500rpm.
Well, the first year for TBI was '87, so I'm guessing something's wrong.
If you can get us a casting number (stamped somewhere on the heads) we will be able to give you a better response.
As for the TBI heads, I wouldn't recommend them, as they limit airflow for torque, as iroc22 said. These heads would be a step-backwards if you were to take off your TPI heads.
I assumed it was TBI but I am not that knowledgible on all of the thirdgens. The only thing that I really know is that the 86 was pretty weak as far as horsepower goes.Unfortunately thats the one I have!) I know for sure that this 85 is not a TPI. So if it is just a plain carberated one will these heads work? I found them at a pick and pull junk yard and I only took a quick look at them. I'd like to have some insight before I pull them off.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
