Rev Limiter?
Old May 15, 2002 | 10:26 PM
Resistance85TA's Avatar
Rev Limiter?
My car seems to go to just a little past 5K and stop? is this normal? do the 85 firebirds come with rev limiters? my engine is in my sig. Thanks Guys
Old May 15, 2002 | 11:19 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
LG4 is air limited. no rev limiter.
Old May 16, 2002 | 03:36 AM
so why does my engine seem to stop at about 5100? Its weird cause it seems like im making power all the way up then it like stops. Is there something wrong with my engine? if its the ignition i have a hypertech coil and cap kit coming by friday. will that help???
Old May 16, 2002 | 06:51 AM
EvilCartman's Avatar
Car: '82 Z28
Valve float maybe? I've had mine up to about 6,500 rpm but usually shift around 5,500 to 5,700.. I do have some stiffer than stock valve springs in though.
Old May 16, 2002 | 07:10 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
As far as stock HEI they're only goof to 4500 and then they fall off. Right now I'm doing new 355 and I also bought the Hypertech kit, they kicker is that they don't send you a coil module so figure another $40.00 shot in the butt for that otherwise your new Hypertech is not working to potential cause it's missing a peice of the puzzle. Then I took it to a guy in town that cuts off the vaccum advance, installs new bushings (my weights were jumping over each other-way worn out), puts it on his machine and sets the springs so it'll be at full advance at 3000rpm. He said after these mods and his magic that the ingition will be good to 9000rpm (all the stock car boys run these) and that it's everybit as good as an MSD as far as spark energy. The only draw back is that with an MSD you can hook up all kinds of nifty rev-limiters, 2 & 3 step boxes, etc...but I'll buy that later after car gets more important stuff done. My original motor was the same way in that it stopped at 5000rpm-I had to let a vette go because of this-man that sucked!
Old May 16, 2002 | 07:35 AM
z28esser's Avatar
Something else to look for is.Some of the F Bodies came with whats called a resistance wire.It's the wire that supplies the voltage to the Distributer.Check it with a volt meter,If it does have a resistance wire it will only be getting 11.5 volts.It was GM's way of taming them down some,so they wouldn't give too much competition to the higher option camaros/firebirds.
Old May 16, 2002 | 02:08 PM
IHI's Avatar
IHI
By chance is that resistance wire the wire wire (on mine anyway) that plugs into the distributor by the battery plug in?
Old May 16, 2002 | 03:06 PM
z28esser's Avatar
The Resistance wire will be the main 12 volt source for the distributer.It's usually pink I believe.It's marked + on the cap.
Old May 16, 2002 | 10:52 PM
i have the msd box hooked up..doesnt that change the voltage thats going into the coil? Its a 6a no limiter. like i said, the hypertech kit should be in tomorrow, and im going to get an hei module to go with it by next week. What do you think i should shift at, with all that stuff done? what will be my rpm limit, cause i dont want to blow this engine.
Old May 16, 2002 | 10:53 PM
just so no one thinks i made a mistake, i do have the in cap coil.
Old May 17, 2002 | 06:19 AM
IHI's Avatar
IHI
As far as shift points go, that's going to be trial and error. With a stock 305 I would keep the revs below 5500 for sure if you want to have longjevity.(show me a dyno where anything but a race motor made more power above 6000 rpm) I've seen some guys pick up .2 by changeing to a lower shfit point 6000 rpm to 5000rpm just because that's where the motors power was and utilized it better.
Old May 17, 2002 | 07:18 AM
z28esser's Avatar
My motor pulls up to 6k but my junk heads choke it...With a good set of vortecs this summer i should be able to shift her around 6,500....
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
