very very happy!!!!!!!!!!
Old May 16, 2002 | 02:42 AM
2ponchos's Avatar
went to the track tonight!!!! ran a 12.83@106mph!! to make this some what tech ran the timing at 34 total advance and had to screw with the fuel pressure.. just needed to get that out of my system!! the night started bad ran the first run 13.4 wasnt pleased lol ran out of fuel near the end of the track.. messed with timing a little and ran a 13..053.. then the 12.83
well there i am done!!
Old May 16, 2002 | 04:01 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Nice fast Formula
What kind of mpg are you getting around town and on the highway?
Old May 16, 2002 | 08:00 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Glad to see you finally got that bird going, now we can all take in a big deep breath and move on to the next project.
you should run a little faster with that setup though...how did she hook up?
Old May 16, 2002 | 08:22 AM
2ponchos's Avatar
not sure what mpg i am getting i need to do something to get my speedo working with out the computer it doesnt work so i dont have an odo either.. but sometime i guess i have to change to a cable driven.. and yes i have some playing to do with the carb yet and i should run faster i havent played with the jets yet.. but i will.. and i still spun a bit 1.8 60 foots... which isnt bad but i do have a really really terrible stumble off the line i need to get a vacum test gauge and probably change the power valve atleast that is what i have been told does that sound right?? but for the first time at the track with hardly any tuning i wouldnt say its bad.. for sure not the best that i think it can run but better then i have ever ran!! i ran the MT sportsman pros.. and i was also running open headers lol i drove it there and drove it home.. loud as hell!!! hopefully getting new exhaust on her real soon going true duals with an x pipe.. so we will see till next time!!! if u guys have any ideas bout the stumble give some input thanks!!
Old May 16, 2002 | 12:59 PM
Engine: 406
Very good without much tune time ..You may want to be careful running around open...If you have "shorty" headers. Fires are common.
Old May 16, 2002 | 01:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The off the line stumble can be tuned out with different accelerator pump cams and shooters. You may have to upgrade to a 50cc pump and linkage kit to get enough volume to launch the car. The power valve is open as soon as you floor the gas pedal and will have no real effect on your launch. With your modest
torque converter this (accelerator pump) is a critcial tuning factor.
Your tires are very pressure sensitive and will work better after some of the tread is burned off. Try around 15 psi.
Interesting to see how you made out at the track as my new motor (406 vortec ) is real simular. Good Luck
Old May 16, 2002 | 09:55 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
I don't know that much about that carb but if you can disconnect the sec. linkage and see if the eng. stumbles on the primarys only. Sec. throttel plates may be opening to soon ??
Auggie
InfernalVortex
Apr 20, 2021 11:31 AM
tyeo098
Nov 30, 2015 06:27 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
buckeyecelt
Sep 24, 2015 05:50 AM
UMI Performance
Sponsored Vendors
Sep 4, 2015 09:22 AM
