unintended accelaration..yikes!
Old May 23, 2002 | 08:04 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
I've been noticing that my rpm seems to be creeping up without me giving it any gas. It does it real slow from 2000 rpm to 2500 rpm then it levels off(my car's a 5spd TPI) When I rev it it drops down. I thought my tb or linkage was filthy so I sprayed it with TB cleaner. It went away for a few weeks then it came back. Any ideas?
Old May 23, 2002 | 09:02 PM
BAK12484's Avatar
check your TPS (throttle position sensor)..maybe it needs to be replaced... or perhaps the throttle cable is kinked and gets stuck at times until you rev it
Old May 26, 2002 | 08:07 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
So you guys think the increasing idle speed problem could be due to a faulty tps sensor? Its just weird that it drops back down when I rev it. I've seen them on CARPARTS.com for 50 bucks. I guess it would be an easy fix if that's the cure.
Old May 26, 2002 | 10:00 AM
Vader's Avatar
Under what conditions does this occur? Cold engine, sitting still, from start up, hot idle, etc.?
Old May 26, 2002 | 11:11 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
Usually after its warmed up. Ill be in 2nd gear in traffic, lift off the gas, and have the rpm start creeping up on me.
Old May 26, 2002 | 03:51 PM
iroc22's Avatar
One time I was driving down the street and my car starting pulling hard. I released the clutch and it revved to 5500. So i turned off the car, started it again and it did the same thing. I got out and fiddled with the throttle cable for a bit, started the car up again and it was fine. My throttle cable just was sticky.
Old May 26, 2002 | 04:49 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I had that BS when my MAF needed replacing.
Old May 26, 2002 | 08:55 PM
IROCracer's Avatar
Check your TPS with a voltmeter first...don't buy one if it isn't junk.
Old May 26, 2002 | 09:18 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
My car is speed density so I dont have a MAF. I'm not too swift with the electronic stuff. How do you check the voltage on the TPS and what would indicate a problem?
Old May 27, 2002 | 08:01 AM
KeithO's Avatar
Not to confuse the issue since the above posts probably have the answer...
However, my 1983 Monte Carlo SS started doing this a few years back. As it turned out, the cruise control unit was going bad and would simply decide to accelerate. Replacing the unit eliminated the problem.
I would check the above recommendations before you look at something as weird as this.
Old May 27, 2002 | 11:20 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
Thats funny that you mention that, it feels like im pressing the accell button on the cruise control when it accellerates. Can I just disconnect the cruise from the throttle linkage to check it?
Old May 28, 2002 | 09:37 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Yup, just detach the cruise cable from the throttle linkage.
Old May 28, 2002 | 01:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't think this is the problem, but make sure the floormat doesn't ram itself underneath the gas pedal.
Old May 28, 2002 | 02:39 PM
MX265
Guest
Posts: n/a
This happens in my IROC as well. But it only happens when I am at idle and the A\C is on. It never does it with the A\C off. I am pretty sure this is normal if the A\C is on as the RPM's are supposed to kick up. Is this what you are reffering to? Just a thought.
Andy
Old May 29, 2002 | 07:35 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
No....its just when I'm driving normally...but the car is hot.
How do I check the TPS?
Old May 30, 2002 | 06:19 AM
MX265
Guest
Posts: n/a
TPIterror,
I just found an article on some of the past reported problems with some models of our cars. It had to do with sudden acceleration. I cannot find the fix for it though. It is apparantly something that has been reported to the Center for Auto Safety. It can be found here:
http://www.autosafety.org/autodefects/GM-F-Car.htm
Here is a quote form this site:
"NHTSA investigated all 1985-88s with 5.0/5.7L engines for sudden acceleration but failed to order a recall."
Unfortunatly it does not offer a resolution. I will keep looking though. If I come across a fix, I'll post it here.
BTW - I know yours is a '90, but it may still apply.
Andy
Chuck84TA
Dec 30, 2012 04:00 PM
Chuck84TA
Oct 2, 2012 03:36 PM
Chuck84TA
Jun 6, 2012 10:27 AM
GTA1990
Feb 16, 2010 10:49 AM
general23cmp
Dec 18, 2006 02:06 PM
