I think my car is dying
Old May 26, 2002 | 05:49 PM
puntank4200's Avatar
Car: '88 Camaro
Engine: v6-173-2.8L
Transmission: Automatic
I have an automatic 173cid '88 Camaro and I’m having a little problem. I just had a tune up and an entire lube change and my car is still acting up. When I accelerate I can fell the car going through the gears up until I reach about sixty. When I reach sixty the RPM's drop down to 1500 even with my foot to the floor. I try taking my foot of the gas and stomping on it with no luck. I tried pumping the gas with no luck. Is this an engine, Trans or diff problem? My mechanic says I should buy a new car but I don't want to. Does anyone have any info on how to correct this problem?
Old May 26, 2002 | 08:47 PM
IROCracer's Avatar
Check to see if you're flexplate is cracked. That might be part of it.
Old May 26, 2002 | 09:34 PM
Car: '88 Camaro
Engine: v6-173-2.8L
Flexplate?
Thanks for replying. Is the flex plate the sheild on the bottom of my trans? If so, how is this causing my problem?
Old May 27, 2002 | 04:27 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Is the car jerking or hesitating...or does it just not kickdown in overdrive? a little more info would be helpful...
i think I would start checking the simple things before I started tearing my engine / tranny apart.
You say you just had a tune-up? Was the problem there before the tune-up?
Old May 27, 2002 | 08:57 AM
Car: '88 Camaro
Engine: v6-173-2.8L
Re.Re
Thank You for replying. Yes the problem was there before the tune up and lube job. The car is not jerking or hesitating, but your right it doesn't kickdown in overdrive.
Old May 27, 2002 | 09:43 AM
Engine: 406
Try this...http://www.sethirdgen.org/tvcable.htm may be what you are looking for...lets hope so..
Old May 27, 2002 | 11:24 AM
Car: '88 Camaro
Engine: v6-173-2.8L
Also
I also find myself adding a pint of trans fluid every week.
Old May 27, 2002 | 02:33 PM
Engine: 406
oops..
Old May 27, 2002 | 02:38 PM
Engine: 406
I think you just found your problem, These 700r4 are VERY sensitive to fluid level.....they dont shift right if they are low. Try to see where it is leaking from...I assume it is leaking out right?
P.s. You may want to find a different mechanic, or better yet, educate yourself about your car and do the work yourself....once you do this, you will see why Mechanics charge so much.....
Let us know what you find out....yu must keep the tranny full..
Old May 27, 2002 | 03:16 PM
Car: '88 Camaro
Engine: v6-173-2.8L
trans fluid
The problem is that i don't see a leak. I figured if i'm losing a pint a week i would see a significant puddle, but i have yet to find a leak or a puddle.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
