ticking lifters
Old Jun 3, 2002 | 07:18 AM
MartyMcFly's Avatar
Car: Z28
Engine: Edelbrockified 305
Transmission: 700-R4
ticking lifters
Within about 1000 miles or so after a cam swap, I noticed a ticking sound whenver I put the engine under load. I was told this was the lifters. Could someone please tell me what would make them do that and how for that matter. Also, is it OK to drive it like this, I've put like 3000 miles on it since it began ticking.
Old Jun 3, 2002 | 07:32 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
You might check for an exhaust leak..."ticks" are usually that. Now "Taps" could be lifters. use the old metal rod stethoscope trick and see if the sound is coming from the valve covers....
Old Jun 3, 2002 | 03:42 PM
johndo1707's Avatar
yeah, on my s10 i thought it was the lifters or something in the valvetrain, but turned out to be an exhaust leak.;
Old Jun 3, 2002 | 05:21 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Me too...hehehe. I had a cracked exhaust manifold after I did my cam swap (nice timing huh?). It drove me nuts.
This is something I learned from the fellas here. If it ticks all the time and gets louder with rpm then it's prolly a valve lash issue. If it's more noticeable at idle and under load then it's prolly an exhaust issue.
I found out for sure by taking the nitrous blow-down tube from my IROC and putting it on the valve covers, then pressing my ear to the other end. Works like a charm...
Old Jun 20, 2002 | 11:09 PM
xaivior's Avatar
Car: Camaro
Engine: 355
Transmission: th-350
Axle/Gears: 3.73 welded
exhaust leak prolly ..like riley said ..i thought mine was doing the same after i broke in my cam but it was the leak
P.S. in you old sig you had a little thing that said "Ludicrous Speed GO!!!Does anyone know what movie this is from?"
i know the movie!! SPACE *****!!!!
:lala:
Old Jun 21, 2002 | 02:28 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
COMB THE DESERT!
Old Jun 21, 2002 | 04:07 AM
EvilCartman's Avatar
Car: '82 Z28
Found anything yet?
Old Jun 21, 2002 | 03:35 PM
Matt87GTA's Avatar
MAN!! ........ We aint found $hit.....
Old Jun 21, 2002 | 04:53 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
befor john candy died they were working on a new spaceballs movie -Spaceballs III - the search for Spaceballs II, as for the ticking problem I'd also say check for an exauast leak, I've hade maneof them.
Old Jun 22, 2002 | 01:03 AM
xaivior's Avatar
Car: Camaro
Engine: 355
Man space ***** III would have been the sH*T that movie was good ...it kinda never got old....
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
