cams
yeah the cam will fit, make sure it's a roller if you have a roller set up, or a flat cam if not a roller. without knowing what the cam is you want to install it's be hard to say if you'd see any gains
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
ummmmmmm did you just use stock and 5 speed in the same sentence? That means you're talking about a 305... LG4 or L69, and not TPI, Carbeurated. If you want a cam out of a 350, it's going to be auto.
Unfortunately they quit offering the best engine with a manual transmission in 81
