rebuilding an engine - is it alright to keep stock cam & just replace lifters??
Old Jun 6, 2002 | 09:42 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
For someone who's on a low budget, when rebuilding an engine is it alright to keep the stock cam and just replace the lifters?? The engine ran fine before but was neglected, major sludge buildup. The lifters are worn but there was never a problem with the way it ran or noise. I know that when you reinstall the cam and lifters they all have to go back together the same way because of how they wear but would installing new lifters with a worn cam cause problems or would it actually help a little??
Old Jun 6, 2002 | 09:48 AM
Jester's Avatar
I suppose you could but there would be NO point whatsoever. Unless a lifter is collapsed or something, leave them alone too. They way to go is replace the cam and leave the lifters...not vice versa.
Old Jun 6, 2002 | 10:06 AM
felo72's Avatar
What year is the Camaro, and what engine do you have along with what setup?
Old Jun 6, 2002 | 11:12 AM
ede's Avatar
ede
if your lifters show wear then your cam is trash too replace them as a set
Old Jun 6, 2002 | 11:47 AM
txturbo's Avatar
cam & lifters
Its never a good idea to replace one or the other. Either put them both back in (assuming you know which lifter goes with which cam lobe) or replace them both.
Old Jun 6, 2002 | 12:26 PM
87transam5.7tpi's Avatar
ya, if you lifters show wear you gotta replace cam and lifters. if they look fine just keep them all in order and don't replace em. if you don't have a roller cam, you can pick up a new one with lifters for like $100 from comp or crane. good luck bro, and if you need any help let me know.
Old Jun 6, 2002 | 01:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: rebuilding an engine - is it alright to keep stock cam & just replace lifters??
Assuming this is the engine in the sig, so 91 = roller lifters. All responses below assume that.
Rollers don't like sludge, but build-up rarely occurs where it'll hurt them.
How do you know they're worn if there's no noise and no problems?
Not really an issue with roller lifters. What you say applies to flat tappet, except that you don't want to put new and old flat tappet parts together, no matter which is old or new, because of previous wear.
Old Jun 6, 2002 | 02:32 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
no it's not out of my 91' Camaro. Thanks for the replies, that's sort of the response I was expecting. I guess I'll replace both.
Old Jun 6, 2002 | 03:43 PM
felo72's Avatar
The reason I asked is because I work at Summit Racing and could get you a price and part number. I'll have to get back to you on Monday though, if you want I could give you a name of someone that could help you if you don't want to wait...
Old Jun 6, 2002 | 04:06 PM
five7kid's Avatar
no it's not out of my 91' Camaro...
It helps when specifics are supplied.
But, now you know: flat tappet means replace both cam & lifters. Cheap these days.
Old Jun 7, 2002 | 03:45 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
aside from rebuilding an engine. What if you have a flat tappet that's making noise is it alright to replace the one or should you replace all??
Old Jun 10, 2002 | 07:49 AM
felo72's Avatar
If it's a hydraulic flat tappet, you should replace them both. If you only choose to replace one and not the other you will definately run into problems and in the long run have to replace them both anyway.
Old Jun 11, 2002 | 09:45 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
the reason I ask is a friends car has a noisy lifter but rather than replace the cam and all the lifters I just want to eliminate the noise. Plus the fact that he doesn't want to pay to replace everything. Noisy lifters are usually due to sticking right? Rather than replace the lifter with a new one would it be better for me to just take that specific lifter apart and clean it out. Isn't varnish build-up usually the problem when lifters start making a noise??
Azrael91966669
25
Jun 20, 2017 04:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
TheExaminer
Aug 25, 2015 07:34 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
