Replacing distributor
Old Jun 7, 2002 | 09:13 PM
86'ROC TPI's Avatar
On a '89 TBI car, can you replace the distributor with a vacuum advance one to eliminate the esc and effectively the knock sensor as well? Will this set a code?
Old Jun 8, 2002 | 01:40 AM
Morley's Avatar
It sure will set a code, several of them probably.
~M~
Old Jun 8, 2002 | 06:27 AM
ede's Avatar
ede
bet it jump straight into limp home mode, leave the est ecm controls in place or eliminate them all
Old Jun 8, 2002 | 09:07 AM
86'ROC TPI's Avatar
I understand that, but isn't limp home mode where the timing is severely retarded? If the ecm has no power over the distributor it cant very well control the timing can it? Or does it mess with the fuel curve also?
jklein337
Sep 19, 2018 06:23 PM
Derick15
Sep 17, 2016 05:28 PM
86IROC112
Aug 17, 2015 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
