Cylinder Head cleaning question!
Old Jun 23, 2002 | 08:39 AM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
I have a set of heads im putting on my thirgen and they're off my other car, and in good condition they just need some of the surface mess cleaned up, im wondering what i should use to clean them that wont hurt anything, theyre all assembled, valves and all
Old Jun 23, 2002 | 10:43 AM
NTChrist's Avatar
I've heard that oven cleaner and a garden hose works well.
Don't be afraid to scrub.
I'm in the same boat, but I disassembled mine, and sent them to a machine shop to be cleaned and magnafluxed.
Old Jun 23, 2002 | 11:15 AM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
I took mine apart, then used wd40 and a scotchbright pad, takes some work but it doesnt scratch or mess anything up. I got some pictures I can put up later on. I actualy only finished 1 so far, I gotta go do the other then put them on.
Old Jun 23, 2002 | 02:32 PM
stevver84Z's Avatar
i dont really wanna take mine apart they were just recently redone, wd40 wont kill anything on em will it?
Old Jun 23, 2002 | 02:55 PM
ede's Avatar
ede
i use a power washer, if you don't have onbe tru the car wash then i use a die grinder with a wire brush and maybe brake cleaner
Old Jun 23, 2002 | 05:12 PM
BenDoe91z28's Avatar
i just got done porting and roller sanding mine, how should i get all those little pieces of aluminum out of the valve guids?
Old Jun 23, 2002 | 11:08 PM
Morley's Avatar
Re: Cylinder Head cleaning question!
Simple Green, a stiff bristle brush and clean water, dry throughly after completion and coat lightly with clean oil (the internal parts that is).
Old Jun 23, 2002 | 11:17 PM
Jza's Avatar
Jza
Dry with muy compressed air.
sweet_87_iroc
Sep 25, 2015 10:01 PM
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
