Eaton O.E.M. Replacement Roller lifters.
Old Jun 27, 2002 | 12:30 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Questions about Eaton O.E.M. Replacement Roller lifters
Im looking at the Eaton roller lifters to get for my new motor. Has anyone used them. I can gets some for 99.99 at Competitionproducts. And that beats the $200 price for the comp cams lifters. Are the Eaton Lifters good pieces?
Old Jun 27, 2002 | 01:22 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
they are really not intended for spring pressures in the 280lb and up range
But, I bet if you called them you would find they are backordered anyway.
NO eta
Old Jun 27, 2002 | 01:45 PM
ede's Avatar
ede
i'd bet eaton makes the lifters for a lot of other people, like comp
Old Jun 27, 2002 | 01:48 PM
Car: 1991 Z28
I called comp products and they say there is a national shortage on lifters but they had some in stock. The cam im planning to run is the CC305 cam 220/230, .510,.510 w/ a 114lsa Do you see a problem there? The springs im running can handle .570" lift the description says
1.850-100lbs,
1,800-110lbs,
1.750-145lbs,
1.500-235lbs.,
1.250 335lbs.,
coilbind 1.150
Old Jun 27, 2002 | 02:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would not run those springs in my motor...
Stock SBC installed height is 1.750". No way a spring that coi-binds at .600" of lift is good to use at a lift up to .570". Sounds like K-motion or similar "little white lies" to me. Also, note that at .510" lift, you're at over 300 lbs of open pressure. You can fudge it a little bit by using the .050" offset keepers, but why do that instead of just getting some quality springs in the first place?
Old Jun 27, 2002 | 02:35 PM
Car: 1991 Z28
Well I dont really know what springs I should go with. Do you have any suggestions? is 300lbs of seat pressure at .510" too much? Sorry I dont understand much about springs
Old Jun 27, 2002 | 02:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Call Comp and see what they say... they're the ones who will warranty the cam if you follow their recommendation, but won't warranty it when it gets eaten if you use the wrong ones...
My guess would be to use their new conical springs (983?) and the matching retainers. But it's just a guess.
Also, get rid of the stock stamped sheet-metal rockers, otherwise the valve train will only deliver about .475" of your .510" cam's lift. I'd recommend the Comp steel-bodied ones.
If you machine your heads for 1.45" springs, use 1.6 rockers.
Old Jun 27, 2002 | 05:18 PM
Dr. Pepper's Avatar
Old Jun 27, 2002 | 05:31 PM
Boxeat2469's Avatar
RB83L69, you said he'd only see .475 of the .510 lift. Do you really think the stock stamped rockers deflect that much?
Old Jun 27, 2002 | 08:25 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
its not deflection.. its accuracy
stock rockers will rarely give a 1.5 ratio.
junkcltr
Aug 2, 2019 11:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
BrianI
Aug 9, 2015 11:52 AM
