Checking for spark?
Old Jun 28, 2002 | 07:39 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Checking for spark?
This may be a stupid question but...
How do i check if one of my plugs is getting spark?
Is there any way to know if it is or not?
Thanks...
Old Jun 28, 2002 | 07:55 AM
ede's Avatar
ede
quick check i just stick a plug in the wire and ground it aginst something and crank engine or use an inductive light. if you want to see if the park is strong enough get a spark checker for around 10 dollars.
Old Jun 28, 2002 | 07:56 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Thanks for the info
Old Jun 28, 2002 | 01:05 PM
Damon's Avatar
For a few dollars you can buy a tester at the local parts store. It looks like a spark plug with a ground clip on the side. Very handy little thing to have. Beats getting juiced with 30,000 Volts if you happen to give the spark an easier path to ground through your body than through a screwdriver, pliers or whatever you use to hold the wire in position to test it otherwise.
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
