distributor install
Old Jun 30, 2002 | 11:42 AM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
distributor install
Distributor will not go all the way into engine. It is about 1/2" to 1" from going all the way down in.
What do I do??
Old Jun 30, 2002 | 11:50 AM
evil t/a's Avatar
Re: distributor install
What do I do??
Its not lining up with the oil pump drive. Easy way is to wiggle the rotor back and fourth rapidly for a few seconds , or you can raise it up a little and turn the shaft a bit and see if it seats all the way.
Old Jun 30, 2002 | 12:00 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
No luck
Should I push down on the housing while doing this?
Which direction is the rotor supposed to turn? Counter-clockwise?
Old Jun 30, 2002 | 12:05 PM
evil t/a's Avatar
No luck
The rotor turns clockwise. If that didnt work the just pull the distributor up and turn the rotor a bit .
Old Jun 30, 2002 | 12:18 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
!!!!!!!!!!!!!YES!!!!!!!!!!!!!
Thank you evil,
First thing to go my way all weekend!
Now I just point rotor tip at #1 and get engine ready to run, and set timing right?
Old Jun 30, 2002 | 01:00 PM
evil t/a's Avatar
Re: !!!!!!!!!!!!!YES!!!!!!!!!!!!!
Thank you evil,
Coool glad that I could help. And yes line the rotor up with the #1 terminal and you should be fine , as long as the #1 cylinder is at TDC
Old Jun 30, 2002 | 01:08 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
I am at TDC,
I just can't turn the rotor now that it is in.
Sorry for causing all these problems. Any suggestions now?
Old Jun 30, 2002 | 02:03 PM
32789RS's Avatar
If the motor is at TDC just watch what terminal on the distributor cap your rotor is pointing at, and put your #1 plug wire on that terminal. you'll also have to the rest of your wires to keep them in the right order.
Old Jun 30, 2002 | 03:26 PM
evil t/a's Avatar
I am at TDC,
Just mark the distributor body at where the #1 terminal is at and turn it to math the rotor.
Old Jun 30, 2002 | 03:36 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Exactly.....
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
