305 -> 350?
Old Jul 1, 2002 | 10:56 AM
85zcamaro's Avatar
305 -> 350?
How do you make a 305 a 350, whats involved? OR is it not possible....?Would it be a waste to try to do it or just buy one already thats a 350?
Old Jul 1, 2002 | 11:07 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
you cant, boring off a 305 to 4" will leave you without cilinder walls, so to speak.
Old Jul 1, 2002 | 11:08 AM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
uhh, im pretty sure you can't make a 305 a 350.....theres no crank for it...
Old Jul 1, 2002 | 12:03 PM
Morley's Avatar
Same crank, not enough cylinder wall thickness to open it to 4"
Old Jul 1, 2002 | 12:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yep, can't be done.
Old Jul 1, 2002 | 01:30 PM
85zcamaro's Avatar
OK thanks guys!!! Din think so but just to make sure...
Old Jul 1, 2002 | 02:07 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Heh..heh... Why dont you invest in the 350 block and build onto it?
Old Jul 1, 2002 | 02:10 PM
johndo1707's Avatar
that's what i'm doing!
Old Jul 1, 2002 | 02:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's real simple.
Remove 305. Set aside.
Install 350.
Done!!
350s are pretty easy to find in most places, especially 2-piece rear-main-seal ones. You want more than just the short block, however; the heads that come on 305s, while they will fit 350s, suck. They are mostly built for gas mileage and good low-RPM torque at the expense of horsepower and general high-RPM performance. But, external things like accessories, exhaust systems, ignition systems, etc. are the same between the 2 sizes.
Old Jul 1, 2002 | 02:54 PM
85zcamaro's Avatar
I dunno why i would wnt too, just never heard of it and wasn't sure.... I was going to do theswap but i've got 2 g's into my car already and have another 1 g to spend, i dont want to put too much money into her right now, and im just not sure what to use the money on
Old Jul 2, 2002 | 02:12 PM
uidzer0_z28's Avatar
I am in the same sort of situation that you are in... I have some money right now and I am putting it into the 305, what I am doing though is purchasing parts that are all going to transfer over to my 350 when someday I get around to putting it in. (intake carb headers etc...)
-Ben
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
