how high can you rev w/ hydrolic lifters?
I was wondering how high you can rev with hydrolic flat tappet lifters if you have matching valve springs. I am assuming that the rest of the motor is set up for it. I just want to know when the lifters have problems.
Ben
Ben
Transmission: 4L80E/4L80E
I go to 6300 with no problems. Don't really want to, but it does it without complaining.
The cam card said valve float @ 6500 RPMs with their recommended springs.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Depending on the design of the cam and the valvetrain
Generally around 6000/6500 is tops.
Your limited by the heavy lifter, limited usuable valvespring pressure on a hydraulic lifter, spring serge. etc
Some people use a "Rev Kit" to stretch this out a bit.
Generally, unless you have a huge camshaft,
you need to shift your car before 6000/6500 rpm
for best acceleration anyways.
If you want a big high rpm cam you'd be better off with a solid roller anyways.
Some "Anti -pump up" lifters have an increased bleed rate.
This can cause a mild ticking sound at idle simular to a solid cam.
The higher the bleed rate for a said oil pressure, the more noise.
Crane, Comp cams and Isky are the better brands
of hi-performance hyd lifters.
This and other factors (spring pressure, cam lobe design, internal lifter clearances and valving/metering) are used in the design of a high reving hydraulic cam valve train system.
Of course this costs a little more but you get what you pay for.
TX-SleeperC5
Sep 24, 2015 03:13 PM
