Headers..?
Car: 89 Firebird
Headers..?
What headers would be good for a 305 with 650 cfm edelbrock carb and edelbrock proformer intake? Motor is going to stay pretty much stock with maybe 1 or 2 more small mods
Well it’s pretty much what iroc said it’s all in the budget or what you can find for cheep. i had edelbrock and i actually did not mind them too much and thought they were not to bad, i took a grinder to the inside of the ports on them because its quite disgusting in there and needs to be cleaned up a bit but other than that there really not that bad also i did not get them jet coated but i did pick up some 1500 deg spray paint and put a few layers on and did not have ONE bit of a problem of rust for little over a year and i live very close to the ocean. but currently i have the slp try-Y design headers that i picked up at a junkyard for 50 bucks a deal that i could not say no to
and there little bit of a bitch when it comes to bolting them up and tiring to make the y pipe to the headers not leak. For a 305 you probably want 5/8 size primaries and a 3/4 would probably be over kill.
and there little bit of a bitch when it comes to bolting them up and tiring to make the y pipe to the headers not leak. For a 305 you probably want 5/8 size primaries and a 3/4 would probably be over kill. Supreme Member
Car: 99 Formula
Axle/Gears: 342
Hooker headers. I don't care for my TES headers. Flowtech is pretty much junk, but if you're lookin for cheap, that's the way to go.
Car: 89 Firebird
thanks for the help guys, i'll go take a look at some hooker and flowtechs, see what the differance between the 2 are.. stock sucks..
camarosource
Sep 21, 2010 08:53 PM
