Smog pump removal and cat
Old Jul 7, 2002 | 05:48 PM
Coop89RS's Avatar
I f I was to remove the smog pump will taht effect the catalytic converter? Doesnt it get the fresh air from pump?
Old Jul 7, 2002 | 05:50 PM
Tas's Avatar
Tas
yep
Old Jul 7, 2002 | 05:55 PM
Coop89RS's Avatar
SO what should I do?
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
if ur removin the smog pump... i assume u dont need to worry about emissions...therefore i would get a 2.25" piece of pipe and delete the cat.
Old Jul 7, 2002 | 05:57 PM
Tas's Avatar
Tas
You'd cap the air line on the cat. Mine is welded shut (used Cat). I probably have to get it to work for smog time in Feb.
Old Jul 9, 2002 | 07:27 PM
Coop89RS's Avatar
Doesn't plugging the line to the cat cause the cat to hit up and do bad bad things.
Old Jul 9, 2002 | 07:49 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
smog pump to cat
Running a hose or line from the smog pump directly to the cat, would that still serve the same purpose as all the hoses from the manifolds to the cat. Wouldn`t doing that would still keep the smog pump and still clean up all the hoses?
Old Jul 9, 2002 | 08:04 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
just do what i do......i live in nj..........my parents live in florida......we all know nj emmissions are tough as hell.....so i registered the car in florida at my parents address..........no emmissions in florida............so 3 inch catback and no cat.....who hoooooo...........
onefreakz
May 14, 2018 12:15 PM
italiano67
Dec 11, 2016 09:21 AM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
