High Torq Starter
Old Jul 10, 2002 | 10:08 AM
ta350400's Avatar
High Torq Starter
Trying to find a high torq mini starter. Looking for suggestions, approx. cost, looks like ill be spending about 250 through summit or jegs.
Old Jul 10, 2002 | 11:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
www.tommyjohnsonjr.com/bs
Old Jul 10, 2002 | 11:49 AM
ede's Avatar
ede
i bought one of the gmpp from local dealer
Old Jul 10, 2002 | 12:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have the CVR one for both bolt patterns (4 bolt holes in the nosepiece) on my 10½:1 400, works like a charm, seems like it was about $170
Old Jul 10, 2002 | 09:57 PM
Mark W. Winning's Avatar
Also look at the 4th gen starters. Most were gear reduction starters from the factory. If you have the right flywheel, it will save you some trouble. Thats what I did with mine. Since it was a bit small, the headers did not effect it either.
Old Jul 10, 2002 | 11:32 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I'm using the CSI high torque start. 1.6 HP motor and cranks motor up to 468 CID and 12:5:1 compression. Fits both 153 or 168 tooth flywheels.
Old Jul 12, 2002 | 11:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Just got the tommyjohnson starter up in the car. Easy to do.
It cost me 120 for the mini/high torque starter. Talk about turning that engine over fast! I could probably drive the car without the engine and just the starter.
Anyway it's also for the 153 or 168 tooth flywheels. My stock starter weighed 19 lbs. this one weighs 10 lbs.
Old Jul 12, 2002 | 08:27 PM
logikal6785's Avatar
hey viper killer i'd been having the same problems you outlined in another thread about not starting - a new starter helped that much? do you have aftermarket headers ? i think my headers have baked the **** out of my starter and i need a new one
Old Jul 15, 2002 | 12:29 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That depends on which thread to which you're referring. Which one?
My starter somehow went bad when I changed my oil pan
sahlomonic
Sep 20, 2015 07:15 PM
Denricci22
Sep 18, 2015 09:02 AM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
corey8084
Sep 17, 2015 02:56 PM
Formula_88AE
Sep 3, 2015 01:47 PM
