so things were going fine today until...
Old Jul 10, 2002 | 09:46 PM
camaroguy99's Avatar
I broke one of the oil pan bolts off in the block . It was the second one small one from the back on the drivers side. I can't drill it out, is it that big of a deal? do you think the pan will leak? This has been a long day.
thanks
Jim
Old Jul 10, 2002 | 10:04 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if its in the corner of the pan then yeah i say it will definitely leak. in the middle of the pan along the side u might be able to get away with. i would just tap it out if i were u.
Old Jul 10, 2002 | 10:07 PM
jfox55's Avatar
DO you have any easy outs. YOu drill out the middle, then insert this reverse thread type bit and as you tighten it it brings out your bolt. Any part store should carry them.
Old Jul 10, 2002 | 10:11 PM
yeah I have a set but the oil pan prevents me from drilling. It's not in the corner its 2 up from the back corner bolt
Old Jul 10, 2002 | 11:05 PM
breathment's Avatar
CAn u not remove the pan
Old Jul 11, 2002 | 12:49 AM
The oil pan is not the easiest thing to remove, and after gettting the engine back in the car and most everything back together I don't want to take it out again. If chances are that it's not going to leak then I'm not going to worry about it. Thanks
Old Jul 11, 2002 | 05:20 AM
ede's Avatar
ede
does your oil pan have the metal rails ( don't know real name) that distribute the clamping force and protect the bolt holes? if not get one and put it on, that'll halp secure the pan to the block.
Old Jul 11, 2002 | 11:13 AM
I'll look for those but I've never seen them. I have a moroso oil pan baybe they're built better then the stock pans?
Fronzizzle
Mar 18, 2019 08:29 PM
Wade787b
Sep 29, 2015 01:15 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Bradsaundry
Aug 12, 2015 12:34 AM
