View Poll Results: Which heads perform better?(without modification)
L98 Aluminum corvette heads
23.53%
L31 Vortec, cast iron
76.47%
Voters: 17. You may not vote on this poll
L98 or L31?
Old Jul 16, 2002 | 01:08 PM
Brian'sIROC's Avatar
L98 or L31?
Which heads are better for overall performance?
L98 corvette aluminum heads
L31 vortec style, cast iron
Old Jul 16, 2002 | 01:52 PM
iroc22's Avatar
The L31 Vortec head will outpower the L98 head no question. It's 10 times more efficient and has eliminate a bunch of restrictions found in previous head designs (ie L98). The more efficient you can be, the more power you can make.
Old Jul 16, 2002 | 04:59 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
The Vortec heads will outflow the L98's.
I got aluminum L98 heads because my stock compression is 8.3:1. So it's the flow AND the compression I was after. If I did my math right I should have 10.1:1 comp after the new heads. I also got a real good deal on them.
Old Jul 16, 2002 | 06:12 PM
alohamike's Avatar
V8 Astro,
How do you like the GMPP 196/206 cam? That's the HT383 cam if I'm not mistaken. I'm gonna put one into a 305 and been looking for someone who's installed one into anything to get their impression of it.
Old Jul 17, 2002 | 12:09 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I took my shortblock and heads into the machine shop yesterday, I'm building up a Vortec 355 for a buddy to put in his S10. The shop owner knew immediatly they were vortecs (chamber shape gives it away easily) and didn't have enough to say about them.
He told me a coupe times, I'm going to have a real healthy motor when I'm done "well over 300hp" he said a few times. And he told me the vortecs have a smaller chamber than they advertise, even with my dished low comp pistons of mine, he figures I will be close to 10:1
10:1 is about the highest I ever want to go on a street engine.
my 9.6:1 in my current vortec 350 (dish pistons also) has enough trouble with our crappy gas as it is.
Old Jul 17, 2002 | 12:56 PM
iroc22's Avatar
Yeah most you will find measure around 61-62cc.
Old Jul 17, 2002 | 05:45 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
port out the l98's and you will have heads that rival the vortecs...but stock to stock the vortecs hands down
Old Jul 18, 2002 | 05:41 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Agree. I've seen articles comparing various heads and generally "stock for stock" the Vortec head beats the Aluminum L98 heads for flow.
However, as mentioned by someone else the Aluminum L98 heads are easily ported and can give impressive flow numbers when done right. Polish the combusiton chambers and they will allow you to run some good spark advance curves. They do give a little weight savings which are also nice.
I don't know if the Vortecs are "angled heads", but the Aluminum L98 heads are. This can be either a disadvantage or an advantage. I find the angled heads of the Aluminum L98s make it a lot easier to access the spark plugs with my headers. Much easier than the "straight plug" Iron Heads.
One problem to be aware of with Aluminum heads, is they need to have bolts re-torqued all the time. I installed my a couple of weeks ago and I am re-torquing the intake and exhaust manifolds a third time. Hopefully, they will settle down, but I have also heard that you do have to "check the bolts" from time to time. You don't have to do this with cast iron.
If you want "maintainence free/minimal maintainence", go with cast iron. A lot of guys forget about the "tinker factor" of aluminum. I did.
Old Jul 19, 2002 | 11:13 AM
iroc22's Avatar
There's a few adavantages that the L31 heads over the L98 heads that are already worked in.
The intake runners on the L98's use the dated pattern that has pushrod clearances that hamper performance. With the L31, it's been raised slightly and relocated nearly eliminating the pushrod clearances which can credit the head to much of its power increases.
The exhaust ports on the L31 use a slightly different design with good curves to gain efficieny on the exhaust side. The L98 (later designs, 88-91) use the D-port exhaust ports that can benefit from some porting, but still cannot really match the curves of the L31.
The combustion chambers are really key. The L98 uses a simple half moon chamber, while the L31 uses a kidney bean shaped chamber which increases quench. If you also see the chamber of the L31, it has somewhat of a pocket where the intake valve sits, which helps the intake charge. The exhaust valve in the L31 is significantly unshrouded which will help expel exhaust gases at any RPM. While they both have fast burn chambers, the L98's plug is aimed in the general direction of the exhaust valve, while the L31's has been placed almost right in the center of the chamber, and there's no question that the design will make tons of power.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
sandman92084
Sep 12, 2015 10:27 PM
