What tourque for screw in studs?
Old Jul 18, 2002 | 05:22 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Old Jul 18, 2002 | 05:28 PM
ede's Avatar
ede
might help if you said where or for what?
Old Jul 18, 2002 | 06:39 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Rocker arm studs, 3/8 . For small chevy
Old Jul 18, 2002 | 10:30 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
ttt
Old Jul 18, 2002 | 11:26 PM
iroc22's Avatar
50 ft-lbs
Old Jul 19, 2002 | 09:01 AM
Merlin's Avatar
Are you threading into cast iron or aluminum?
Old Jul 19, 2002 | 11:45 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Cast Vortecs!
Old Jul 19, 2002 | 05:09 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I ran mine to 70lbs. with Loc-Tite.
Old Jul 19, 2002 | 10:00 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Are you talking about the torque needed to mount the studs into the head, or the nut on the stud to hold the heads on?
When you install the studs into the heads, you should not go over 10 ft.lbs. You will put undo stress on the studs if you go more than that.
The Loctite is not needed either. Loctite should only be used on external engine components that will not see any oil (unless you have a leak ).
But as johnsjj2 said, the nuts should be torqued to 70 ft.lbs. when using engine oil (straight 30 weight).
AJ
Old Jul 19, 2002 | 10:25 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Sorry, but you got me really messed up now. I just bought screw in rocker studs. I then pulled the pressed in rocker studs out and tapped the holes. I am talking about the rocker stud, not the rocker nut which holds the rocker arm down. I only have roller tip rockers, maybe this caused the confusion. So I gather that 70 lbs is the torque.
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
